Building and uploading the spiffs data folder works when I use the build task and then the upload task. But it isn’t happening when I run the upload task (array on bottom bar). Here is my platformio.ini file …
Is this still not supported? It is a real pain to run the two tasks manually. I change data files on most firmware updates (I have a web app in the data folder and it changes most debug cycles). Could the two manual tasks at least be combined into one?
