I am using ESP32 board, espressif 32 platform, to do my project.
But, I keep facing this SPI.h library problem which mentioned that the file has error with the variable declaration, as below.
Can someone guide me what should I do with this library error, I have tried to add and change to different libraries, but still not able to solve the problem, keep showing the error, please help me TT
These are the github links that I have included, but the SPI and Adafruit ButIO still showing the error, I have no idea on it…
<< platformio.ini >>
https://github.com/adafruit/Adafruit_MPL3115A2_Library.git
https://github.com/PaulStoffregen/SPI.git
https://github.com/avishorp/TM1637.git
https://github.com/MrRobotrick/GY-NEO6MV2_GPS_Module.git
https://github.com/junhuanchen/Esp32-SoftwareSerial.git
https://github.com/adafruit/Adafruit_BusIO.git
https://github.com/espressif/arduino-esp32.git
https://github.com/arduino/ArduinoCore-avr.git
Please do not post file contents as screenshots.
Use preformatted text by enclosing the text in three backticks:
your code or file content here
Libraries that you include, but which are not compatible with the ESP32 architecture or are even unnecessary:
- GitHub - PaulStoffregen/SPI: SPI library for Teensy & Arduino IDE:
Teensy not ESP32!
- GitHub - arduino/ArduinoCore-avr: The Official Arduino AVR core:
AVR not ESP32!
- GitHub - espressif/arduino-esp32: Arduino core for the ESP32
Totally wrong. Platform and framework is defined by platform and framework setting
On top of all the right things @sivar2311 said, try using this platformio.ini instead.
adafruit/Adafruit MPL3115A2 Library@^2.1.2
mikalhart/TinyGPSPlus@^1.0.3
plerup/EspSoftwareSerial@^8.2.0
adafruit/Adafruit BusIO@^1.15.0
I’ve removed all unnecessary ones, used more mainstream library for some (e.g. the direct TinyGPSPlus library instead of that old fork, or a newer version of the EspSoftwareSerial), and the PlatformIO Registry with stable versioning instead of git links (if they were registered).
@maxgerhardt
Understand, I used to copy and paste all the libraries from the github, until I learned a tutorial YouTube video which guides to add the libraries by clicking the Quick Access, then click Libraries… Really appreciate the opinion and all the guidance. Thanks a lot. <3
@sivar2311
Understand, next time will change to preformatted text instead of screenshot the images.
Ok, I will take notes on those libraries and will be careful and more focusing on deciding the libraries from github.
Thanks for the guidance <3
