Hi, i just published the DCS-BIOS library in cooperation with the guys that own the repo, but the installation page lists Addresses.h in “Include it” in the Installation step. Thats not the proper header, can i point the repository system to the right header “DcsBios.h” using library.properties? We don’t want to rename the main header to DCS-BIOS.h because there are a lot of users and docs pointing to “DcsBios.h” already. PlatformIO Registry
Give your library a library.json
file and specify the headers
attribute.
Will it work with library.properties as well? Don’t want two places where i have to bump the version number every time.
Try it. library.properties
also specifies includes
https://arduino.github.io/arduino-cli/0.19/library-specification/
- includes - (available from Arduino IDE 1.6.10) (optional) a comma separated list of files of the library to be added to the sketch as
#include <...>
lines. This property is used with the “Include library” command in the Arduino IDE. If theincludes
property is missing, all the header files (.h) on the root source folder are included.
I put both includes and headers there to point to the same file, cant hurt. Worked in a test repo, waiting for PR to main repo to be accepted. Thank you
