Hello!
I have a project which I am trying to migrate from ArduinoIDE to PlatformIO. When I create a “Hello World” .bin using PlatformIO I am not able to see it run on my device. I am able to run code built by ArduinoIDE.
Here is my “hello world” code:
#include <Wire.h>
Wire.begin();
while (!Serial);
Serial.println("ready");
Serial.println("hello, world");
delay(5000);
The relevant part of my platformio.ini
is:
[env:stable]
platform = ststm32
board = sparkfun_micromod_f405
upload_protocol = dfu
monitor_port = COM4
To configure ArduinoIDE I:
- Added an additional Board URL: https://raw.githubusercontent.com/sparkfun/Arduino_Boards/main/IDE_Board_Manager/package_sparkfun_index.json
- Install SparkFun STM32 Boards and use Generic STM32F4 series
- Select SparkFun MicroMod STM32F405 DFU
PlatformIO documentation for sparkfun_micromod_f405 is:
"build": {
"arduino": {
"variant_h": "variant_MICROMOD_F405.h"
"core": "stm32",
"cpu": "cortex-m4",
"extra_flags": "-DSTM32F4 -DSTM32F405xx",
"f_cpu": "168000000L",
"framework_extra_flags": {
"arduino": "-DCUSTOM_PERIPHERAL_PINS -DARDUINO_MICROMOD_F405"
"mcu": "stm32f405rgt6",
"product_line": "STM32F405xx",
"variant": "STM32F4xx/F405RGT_F415RGT",
"zephyr": {
"variant": "sparkfun_micromod_stm32f405"
"debug": {
"jlink_device": "STM32F405RG",
"openocd_target": "stm32f4x",
"svd_path": "STM32F40x.svd"
"frameworks": [
"arduino",
"cmsis",
"stm32cube",
"libopencm3",
"zephyr"
"name": "SparkFun MicroMod STM32F405",
"upload": {
"maximum_ram_size": 131072,
"maximum_size": 1048576,
"protocol": "stlink",
"protocols": [
"dfu",
"serial",
"jlink",
"stlink",
"blackmagic"
"url": "https://www.sparkfun.com/products/17713",
"vendor": "SparkFun"
I note that url points to products/17713 which is an older version of the product and that products/21326 is the current version. It’s unclear to me if this means that other pieces of this definition are stale and interfering with my needs.
I also note that framework_extra_flags
is being given -DARDUINO_MICROMOD_F405
but potentially needs to be given -DARDUINO_MICROMOD_F405_DFU
. I don’t know what this would do, but in the build logs provided below I see the _DFU
variant being used in the ArduinoIDE build logs.
Potentially a red herring, but when I look at the .bin
’s created by PlatformIO and ArduinoIDE I see a significant size discrepancy. ArduinoIDE generates a .bin
that’s ~43kb and PlatformIO generates one which is ~21kb.
I also note that ArduinoIDE is using arm-none-eabi 9.3.1-1.3
where PlatformIO is using 12.3.1
If it’s helpful, here is the output I get when I compile with verbosity using each platform:
ArduinoIDE:
FQBN: SparkFun:stm32:GenF4:pnum=MICROMOD_F405,usb=CDCgen,rtlib=nanofp
Using board 'GenF4' from platform in folder: C:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0
Using core 'arduino' from platform in folder: C:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0
"C:\\Users\\MeoDesktop\\AppData\\Local\\Arduino15\\packages\\SparkFun\\tools\\STM32Tools\\2.0.0/win/busybox.exe" sh "C:\\Users\\MeoDesktop\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\stm32\\2.1.0\\system/extras/prebuild.sh" "C:\\Users\\MeoDesktop\\AppData\\Local\\Temp\\arduino\\sketches\\373E4CA0A0B524B5D7949FE51C570930" "C:\\Users\\MeoDesktop\\Desktop\\sketch_may28a"
Detecting libraries used...
C:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\tools\xpack-arm-none-eabi-gcc\9.3.1-1.3/bin/arm-none-eabi-g++ -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -DUSE_FULL_LL_DRIVER -mthumb @C:\Users\MeoDesktop\AppData\Local\Temp\arduino\sketches\373E4CA0A0B524B5D7949FE51C570930/sketch/build_opt.h -c -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -IC:\Users\MeoDesktop\Desktop\sketch_may28a -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino/avr -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino/stm32 -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino/stm32/LL -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino/stm32/usb -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino/stm32/OpenAMP -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino/stm32/usb/hid -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino/stm32/usb/cdc -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Drivers/STM32F4xx_HAL_Driver/Inc -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Drivers/STM32F4xx_HAL_Driver/Src -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/STM32F4xx -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Middlewares/ST/STM32_USB_Device_Library/Core/Src -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Middlewares/OpenAMP -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Middlewares/OpenAMP/open-amp/lib/include -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Middlewares/OpenAMP/libmetal/lib/include -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Middlewares/OpenAMP/virtual_driver -w -x c++ -E -CC -DSTM32F4xx -DARDUINO=10607 -DARDUINO_MICROMOD_F405_DFU -DARDUINO_ARCH_STM32 -DBOARD_NAME="MICROMOD_F405_DFU" -DVARIANT_H="variant_MICROMOD_F405_DFU.h" -DSTM32F405xx -DUSBCON -DUSBD_VID=0 -DUSBD_PID=0 -DHAL_PCD_MODULE_ENABLED -DUSBD_USE_CDC -DHAL_UART_MODULE_ENABLED -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\tools\CMSIS\5.7.0/CMSIS/Core/Include/ -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Drivers/CMSIS/Device/ST/STM32F4xx/Include/ -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\system/Drivers/CMSIS/Device/ST/STM32F4xx/Source/Templates/gcc/ -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\tools\CMSIS\5.7.0/CMSIS/DSP/Include -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\tools\CMSIS\5.7.0/CMSIS/DSP/PrivateInclude -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\cores\arduino -IC:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\variants\STM32F4xx\F405RGT_F415RGT C:\Users\MeoDesktop\AppData\Local\Temp\arduino\sketches\373E4CA0A0B524B5D7949FE51C570930\sketch\sketch_may28a.ino.cpp -o nul
<truncated for brevity>
Using cached library dependencies for file:
<...lots of cached deps here>
Generating function prototypes...
Compiling libraries...
Compiling library "Wire"
<...lots of previously compiled files here>
Using precompiled core: C:\Users\MeoDesktop\AppData\Local\Temp\arduino\cores\7a87c0ca3040e9a96beb232255eb2a08\core.a
Linking everything together...
"C:\\Users\\MeoDesktop\\AppData\\Local\\Arduino15\\packages\\SparkFun\\tools\\xpack-arm-none-eabi-gcc\\9.3.1-1.3/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mthumb -Os --specs=nano.specs -u _printf_float -Wl,--defsym=LD_FLASH_OFFSET=0 -Wl,--defsym=LD_MAX_SIZE=1048576 -Wl,--defsym=LD_MAX_DATA_SIZE=131072 -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common "-Wl,--default-script=C:\\Users\\MeoDesktop\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\stm32\\2.1.0\\variants\\STM32F4xx\\F405RGT_F415RGT/ldscript.ld" "-Wl,--script=C:\\Users\\MeoDesktop\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\stm32\\2.1.0\\system/ldscript.ld" "-Wl,-Map,C:\\Users\\MeoDesktop\\AppData\\Local\\Temp\\arduino\\sketches\\373E4CA0A0B524B5D7949FE51C570930/sketch_may28a.ino.map" <...lots of build artifacts here>
Using library Wire at version 1.0 in folder: C:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\libraries\Wire
Using library Source Wrapper at version 1.0.1 in folder: C:\Users\MeoDesktop\AppData\Local\Arduino15\packages\SparkFun\hardware\stm32\2.1.0\libraries\SrcWrapper
"C:\\Users\\MeoDesktop\\AppData\\Local\\Arduino15\\packages\\SparkFun\\tools\\xpack-arm-none-eabi-gcc\\9.3.1-1.3/bin/arm-none-eabi-size" -A "C:\\Users\\MeoDesktop\\AppData\\Local\\Temp\\arduino\\sketches\\373E4CA0A0B524B5D7949FE51C570930/sketch_may28a.ino.elf"
Sketch uses 42776 bytes (4%) of program storage space. Maximum is 1048576 bytes.
Global variables use 4536 bytes (3%) of dynamic memory, leaving 126536 bytes for local variables. Maximum is 131072 bytes.
PlatformIO:
* Executing task: C:\Users\MeoDesktop\.platformio\penv\Scripts\platformio.exe run
Processing stable (platform: ststm32; board: sparkfun_micromod_f405; framework: arduino)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/sparkfun_micromod_f405.html
PLATFORM: ST STM32 (17.4.0) > SparkFun MicroMod STM32F405
HARDWARE: STM32F405RGT6 168MHz, 128KB RAM, 1MB Flash
DEBUG: Current (blackmagic) External (blackmagic, jlink, stlink)
- framework-arduinoststm32 @ 4.20701.0 (2.7.1)
- framework-cmsis @ 2.50900.0 (5.9.0)
- tool-dfuutil @ 1.11.0
- toolchain-gccarmnoneeabi @ 1.120301.0 (12.3.1)
Found 14 compatible libraries
|-- Wire @ 1.0.0
Compiling .pio\build\stable\FrameworkArduinoVariant\PeripheralPins.c.o
Compiling .pio\build\stable\FrameworkArduinoVariant\PeripheralPins_FEATHER_F405.c.o
Compiling .pio\build\stable\FrameworkArduinoVariant\PeripheralPins_MICROMOD_F405.c.o
Compiling .pio\build\stable\FrameworkArduinoVariant\generic_clock.c.o
Compiling .pio\build\stable\FrameworkArduinoVariant\variant_FEATHER_F405.cpp.o
Compiling .pio\build\stable\FrameworkArduinoVariant\variant_MICROMOD_F405.cpp.o
Compiling .pio\build\stable\FrameworkArduinoVariant\variant_generic.cpp.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_adc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_adc_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_can.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_cec.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_comp.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_comp_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_cordic.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_cortex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_crc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_crc_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_cryp.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_cryp_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dac.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dac_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dcache.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dma.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dma2d.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dma_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dsi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_dts.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_eth.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_eth_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_exti.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_fdcan.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_firewall.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_flash.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ramfunc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_fmac.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_fmpsmbus.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_fmpsmbus_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_gfxmmu.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_gfxtim.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_gpio.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_gpio_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_gpu2d.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_gtzc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_hash.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_hash_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_hcd.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_hrtim.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_hsem.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_i2c.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_i2c_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_i2s.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_i2s_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_i3c.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_icache.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_ipcc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_irda.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_iwdg.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_jpeg.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_lcd.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_lptim.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_ltdc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_ltdc_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_mdf.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_mdios.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_mdma.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_mmc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_mmc_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_nand.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_nor.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_opamp.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_opamp_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_ospi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_otfdec.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_pccard.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_pcd.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_pcd_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_pka.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_pssi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_pwr.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_pwr_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_qspi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_ramcfg.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_ramecc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_rcc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_rcc_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_rng.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_rng_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_rtc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_rtc_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_sai.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_sai_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_sd.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_sd_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_sdadc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_sdram.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_smartcard.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_smartcard_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_smbus.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_smbus_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_spdifrx.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_spi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_spi_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_sram.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_subghz.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_swpmi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_tim.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_tim_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_tsc.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_uart.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_uart_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_usart.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_usart_ex.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_wwdg.c.o
Compiling .pio\build\stable\SrcWrapper\src\HAL\stm32yyxx_hal_xspi.c.o
Compiling .pio\build\stable\SrcWrapper\src\HardwareTimer.cpp.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_adc.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_bdma.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_comp.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_cordic.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_crc.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_crs.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_dac.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_delayblock.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_dlyb.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_dma.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_dma2d.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_exti.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_fmac.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_fmc.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_fmpi2c.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_fsmc.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_gpio.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_hrtim.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_i2c.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_i3c.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_icache.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_lpgpio.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_lptim.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_lpuart.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_mdma.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_opamp.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_pka.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_pwr.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_rcc.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_rng.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_rtc.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_sdmmc.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_spi.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_swpmi.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_tim.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_ucpd.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_usart.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_usb.c.o
Compiling .pio\build\stable\SrcWrapper\src\LL\stm32yyxx_ll_utils.c.o
Compiling .pio\build\stable\SrcWrapper\src\new.cpp.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\PortNames.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\analog.cpp.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\bootloader.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\clock.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\core_callback.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\dwt.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\hw_config.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\interrupt.cpp.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\otp.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\pinmap.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\stm32_def.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\system_stm32yyxx.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\timer.c.o
Compiling .pio\build\stable\SrcWrapper\src\stm32\uart.c.o
Compiling .pio\build\stable\SrcWrapper\src\syscalls.c.o
Compiling .pio\build\stable\src\main.cpp.o
Compiling .pio\build\stable\libffe\Wire\Wire.cpp.o
Compiling .pio\build\stable\libffe\Wire\utility\twi.c.o
Compiling .pio\build\stable\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\stable\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\stable\FrameworkArduino\Print.cpp.o
Compiling .pio\build\stable\FrameworkArduino\RingBuffer.cpp.o
Compiling .pio\build\stable\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\stable\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\stable\FrameworkArduino\USBSerial.cpp.o
Compiling .pio\build\stable\FrameworkArduino\VirtIOSerial.cpp.o
Compiling .pio\build\stable\FrameworkArduino\WInterrupts.cpp.o
Compiling .pio\build\stable\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\stable\FrameworkArduino\WSerial.cpp.o
Compiling .pio\build\stable\FrameworkArduino\WString.cpp.o
Compiling .pio\build\stable\FrameworkArduino\abi.cpp.o
Compiling .pio\build\stable\FrameworkArduino\avr\dtostrf.c.o
Compiling .pio\build\stable\FrameworkArduino\board.c.o
Compiling .pio\build\stable\FrameworkArduino\core_debug.c.o
Compiling .pio\build\stable\FrameworkArduino\hooks.c.o
Compiling .pio\build\stable\FrameworkArduino\itoa.c.o
Compiling .pio\build\stable\FrameworkArduino\main.cpp.o
Compiling .pio\build\stable\FrameworkArduino\pins_arduino.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\device.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\generic\condition.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\generic\cortexm\sys.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_device.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_init.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_io.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_shmem.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\generic\time.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\init.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\io.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\log.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\libmetal\shmem.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\mbox_ipcc.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\open-amp\remoteproc\remoteproc_virtio.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\open-amp\rpmsg\rpmsg.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\open-amp\rpmsg\rpmsg_virtio.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\openamp.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\rsc_table.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\virt_uart.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\virtio\virtio.c.o
Archiving .pio\build\stable\libffe\libWire.a
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\virtio\virtqueue.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\virtio_buffer.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\OpenAMP\virtio_log.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\startup_stm32yyxx.S.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\cdc\cdc_queue.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\cdc\usbd_cdc.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\cdc\usbd_cdc_if.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\hid\usbd_hid_composite.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\hid\usbd_hid_composite_if.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\usb_device_core.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\usb_device_ctlreq.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\usb_device_ioreq.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\usbd_conf.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\usbd_desc.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\usbd_ep_conf.c.o
Compiling .pio\build\stable\FrameworkArduino\stm32\usb\usbd_if.c.o
Compiling .pio\build\stable\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\stable\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\stable\FrameworkArduino\wiring_pulse.cpp.o
Compiling .pio\build\stable\FrameworkArduino\wiring_shift.c.o
Compiling .pio\build\stable\FrameworkArduino\wiring_time.c.o
Archiving .pio\build\stable\libFrameworkArduino.a
Linking .pio\build\stable\firmware.elf
c:/users/meodesktop/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: .pio/build/stable/firmware.elf has a LOAD segment with RWX permissions
Checking size .pio\build\stable\firmware.elf
RAM: [ ] 1.1% (used 1456 bytes from 131072 bytes)
Flash: [ ] 1.9% (used 20372 bytes from 1048576 bytes)
Building .pio\build\stable\firmware.bin
Adding dfu suffix to firmware.bin
dfu-suffix (dfu-util) 0.11
Copyright 2011-2012 Stefan Schmidt, 2013-2020 Tormod Volden
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Suffix successfully added to file
After I upload the code built by PlatformIO, my serial monitor does not connect to the device and I don’t see it using a COM port when I look for it in device manager.
I don’t really know what to look for here. I might be completely off in the weeds. There might be some clear as day incompatibility. Maybe I just need to tweak one argument somewhere? Or maybe there’s complete lack of support for this newer version?
Is anyone able to offer any guidance to me on why my PlatformIO build might not be working? I am confident it’s the build process and not the upload process. If I take the ArduinoIDE build artifacts and overwrite my PlatformIO build artifacts with them then I am able to successfully upload and run the code.
Thanks
