I am developing a program with the PlatformIO framework for an ESP32 board.
To execute some unit tests I set up a ‘native’ environment.
The program to be unit tested is ‘Syslog.cpp’ under the default source folder ‘${Project}/test’.
The mock files for the unit test are in ‘${Project}/test/mocks’.
The ‘platformio.ini’ file is:
[env]
build_src_filter =
+<Syslog.cpp>
[env:nodemcu-32s]
board = nodemcu-32s
monitor_speed = 921600
paulstoffregen/Time@^1.6.1
-std=gnu++17
-D__time_t_defined
-I src
-I include
build_src_filter =
${env.build_src_filter}
[env:native]
platform = native
-std=gnu++17
-D USING_ARDUINO_FAKE
-D TEST
-D UNIT_TEST
-D__time_t_defined
-I src
-I include
-I test/mocks
; ignore warnings pragmas for now, TODO: fix these
-w
build_src_filter =
+<test/*.cpp>
+<test/mocks/*.cpp>
throwtheswitch/Unity@^2.5.2
fabiobatsilva/ArduinoFake@^0.4.0
This is how my folder structure looks like:
├── Changelog.md
├── LICENSE
├── README.md
├── include
│ ├── ITime.h
│ ├── IUDP.h
│ └── WProgram.h
├── keywords.txt
├── library.json
├── library.properties
├── platformio.ini
├── src
│ ├── Syslog.cpp
│ └── Syslog.h
└── test
├── 00_main_test.cpp
├── 01_unit_test.cpp
├── 02_set_time.cpp
└── mocks
├── MockTimeLib.cpp
├── MockTimeLib.h
└── MockUDP.h
It looks like according to the compiler output that the build_src_filter
instructions are not honored at all. Neither my Syslog.cpp
nor MockTimeLib.cpp
are getting compiled.
This is the compiler output:
platformio.exe test -e native -vv
Collected 1 tests (*)
Processing * in native environment
Building...
Found 2 compatible libraries
|-- Unity @ 2.5.2
|-- ArduinoFake @ 0.4.0
Building in test mode
Compiling .pio\build\native\unity_config_build\unity_config.o
Compiling .pio\build\native\test\00_main_test.o
Compiling .pio\build\native\test\01_unit_test.o
Compiling .pio\build\native\test\02_set_time.o
Compiling .pio\build\native\libbe1\Unity\unity.o
Compiling .pio\build\native\lib730\ArduinoFake\ArduinoFake.o
Compiling .pio\build\native\lib730\ArduinoFake\ClientFake.o
Compiling .pio\build\native\lib730\ArduinoFake\EEPROMFake.o
Compiling .pio\build\native\lib730\ArduinoFake\FunctionFake.o
Compiling .pio\build\native\lib730\ArduinoFake\PrintFake.o
Compiling .pio\build\native\lib730\ArduinoFake\SPIFake.o
Compiling .pio\build\native\lib730\ArduinoFake\SerialFake.o
Compiling .pio\build\native\lib730\ArduinoFake\StreamFake.o
Compiling .pio\build\native\lib730\ArduinoFake\WireFake.o
Compiling .pio\build\native\lib730\ArduinoFake\arduino\IPAddress.o
Compiling .pio\build\native\lib730\ArduinoFake\arduino\WString.o
Compiling .pio\build\native\lib730\ArduinoFake\arduino\noniso.o
Archiving .pio\build\native\libbe1\libUnity.a
Indexing .pio\build\native\libbe1\libUnity.a
Archiving .pio\build\native\lib730\libArduinoFake.a
Indexing .pio\build\native\lib730\libArduinoFake.a
Linking .pio\build\native\program.exe
.pio\build\native\test\00_main_test.o:00_main_test.cpp:(.text+0x41): undefined reference to `Syslog::Syslog(IUDP&, unsigned char)'
.pio\build\native\test\01_unit_test.o:01_unit_test.cpp:(.text+0x35): undefined reference to `Syslog::Syslog(IUDP&, unsigned char)'
.pio\build\native\test\02_set_time.o:02_set_time.cpp:(.text+0x5b): undefined reference to `setTime(int, int, int, int, int, int)'
.pio\build\native\test\02_set_time.o:02_set_time.cpp:(.text+0x93): undefined reference to `hour()'
.pio\build\native\test\02_set_time.o:02_set_time.cpp:(.text+0xe5): undefined reference to `minute()'
.pio\build\native\test\02_set_time.o:02_set_time.cpp:(.text+0x137): undefined reference to `second()'
.pio\build\native\test\02_set_time.o:02_set_time.cpp:(.text+0x189): undefined reference to `day()'
.pio\build\native\test\02_set_time.o:02_set_time.cpp:(.text+0x1db): undefined reference to `month()'
.pio\build\native\test\02_set_time.o:02_set_time.cpp:(.text+0x22d): undefined reference to `year()'
What am I missing? Thanks for any help.
