Sonoff Basic Upload problem Hard Resetting via RTS pin
I’ve a simple sketch for the ITEAD Sonoff basic. When I upload with arduino IDE the sketch works ok.
int gpio13Led = 13;
void setup(void)
  pinMode(gpio13Led, OUTPUT);
  digitalWrite(gpio13Led, HIGH);
  delay(5000);
void loop(void){
  digitalWrite(gpio13Led,HIGH);
  delay(1000);
  digitalWrite(gpio13Led,LOW);
  delay(1000);
I notice that the Arduino IDE upload process ends with soft resetting.
When I however try to upload this sketch with Platform IDE (VSCode 1.14.1 / Platform IO Home 3.0.1 Core 4.1.0) the upload process is exited with Hard Resetting via RTS pin and the sketch does not work.
How can I make the sketch to work. Probably how can I exit the upload with a soft reset ?
Any help appreciated.
Tkx !
Leo
Could you go to your home folder (C:\Users\<user> or /home/<user>), and therenon to .platformio/platforms/espressif8266/builder/main.py
locate the code
Then add modify the UPLOADFLAGS so that it reads
        UPLOADERFLAGS=[
            "--chip", "esp8266",
            "--port", '"$UPLOAD_PORT"',
            "--baud", "$UPLOAD_SPEED",
            "--after", "soft_reset",
            "write_flash"
Then a verbose upload log please (pio run -t upload -v) or Verbose Upload), starting at the invocation of esptooly.py.
Hi Max,
It works !
Here is the output, indeed soft resetting.
Many tkx for the professional help !!
Best wishes
Leo
You can find the answer here.
