Hi, how i can set only one job (-j1) in a multihread build?
i have some error in the code but i cant find witch fail when build it in pio because is builded in miltithread mode (40threads in my machine). i think set “-j1” when build i can able depure the code
any hint? I cant find it in the documentation
greetings
Implemented in PlatformIO Core 4.0. See Redirecting...
Hi, that is implemented in the rc releases?, Because i use platformio rc builds (used rc3 or rc4 when wrote the post)
Greetings
PlatformIO Core 4.0 has been just released => Releases · platformio/platformio-core · GitHub
Please switch to the stable version via pio upgrade
Hey, guys!
Please specify where I need use this option: “-j, --jobs” if I use VSCode?
Thanks!
When you want to do what exactly? Compile on all cores or use a single core?
@ivankravets can you change default --jobs
value for a pio run
call in the VSCode extension settings? I think that would solve his problem.
Yes, there is an option for this case:
Also, @savenko_egor can create custom task with own pio run
options Redirecting...
Blockquote
http://docs.platformio.org/en/latest/userguide/cmd_run.html#cmdoption-platformio-run-j
I see this link. Thanks. But I don’t know where I need use this option in VSCode.
You can specify?
Read the second bit of the reply specifically addressed to you
options http://docs.platformio.org/en/latest/ide/vscode.html#custom-tasks
Hint: Ivan’s saying you can add custom tasks, with which you can then specify options like -j
Okay. Thanks for all!
I will try use custom task.
I tried this, per this conversation :
"version": "2.0.0",
"tasks": [
"type": "PlatformIO",
"task": "Build",
"problemMatcher": [
"$platformio"
"group": "build",
"label": "PlatformIO: Build",
"options": {
"shell": {
"executable": "platformio",
"args": [
"-j", "1"
But that doesn’t seem to be working.
