Processing uno (platform: atmelavr; framework: arduino; board: uno)
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.3.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
|-- <SoftwareSerial> 1.0
Compiling .pio\build\uno\src\main.cpp.o
Compiling .pio\build\uno\liba9f\SoftwareSerial\SoftwareSerial.cpp.o
Archiving .pio\build\uno\libFrameworkArduinoVariant.a
Compiling .pio\build\uno\FrameworkArduino\CDC.cpp.o
In file included from src\main.cpp:4:0:
include/./SoftwareServo.h:4:10: fatal error: WProgram.h: No such file or directory
* Looking for WProgram.h dependency? Check our library registry!
* CLI > platformio lib search "header:WProgram.h"
#include <WProgram.h>
compilation terminated.
*** [.pio\build\uno\src\main.cpp.o] Error 1
Wprogram.h
is only used in very very old (pre v1.00 I think) versions of the Arduino IDE. More recend versions use Arduino.h
instead.
I rather suspect that SoftwareServo.h
is not compatible. Try using Servo.h
instead as that’s usable in the Arduino framework.
Cheers,
Norm.
