Hi there, I am relatively new user to PIO and have come across a few things that I would like some help with if possible, thank you for your patience and time!
- Recompilation:
Occasionly PIO will recompile the core framework libraries (mbed or teensyduino), this happens even though I have only edited a few lines of code within main.cpp. I’ve read that this can happen when the platformio.ini is edited, but I haven’t touched this file.
Furthermore, this also happens when attempting to build/run the debugger. I assume there are two different build configurations between debug build and standard build, and this causes PIO to rebuild the entire library.
Library Compilation
Why does PIO compile the entire mbed library/framework even though I only include specific parts of it? -
Debugger
I am having trouble using the debugger, I get the following error message:Info : Target voltage: 3.239843
Info : stm32l4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : accepting ‘gdb’ connection from pipe
Info : device id = 0x10036470
Warn : Cannot identify target as a STM32L4 family.
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use ‘gdb_memory_map disable’.
Error: attempted ‘gdb’ connection rejected
Ignoring packet error, continuing…
warning: unrecognized item “timeout” in “qSupported” response
I am using macosx, so I assume I don’t need an STLink driver.
Do I need a seperate debug environment configuration in platformio.ini for the debugger to work?
Thanks for your time.
