ok this is for raw, and how to switch the terminal into a bash compatible shell ?
As you can see below there is no changes with this command (platformio device monitor --raw), so I need to change the terminal into a bash compatible terminal isn’t, it ? but how to do this ?
Microsoft Windows [version 6.3.9600]
(c) 2013 Microsoft Corporation. Tous droits réservés.
C:\Users\charafeddine\Documents\PlatformIO\Projects\180903-182438-espidf-hello-w
orld>platformio device monitor --raw
--- Miniterm on COM7 115200,8,N,1 ---
Restarting in 4 seconds...
Restarting in 3 seconds...
Restarting in 2 seconds...
Restarting in 1 seconds...
Restarting in 0 seconds...
Restarting now.
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x3e (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5540
load:0x40078000,len:0
load:0x40078000,len:13560
entry 0x400790a8
[0;32mI (28) boot: ESP-IDF 3.30003.0 2nd stage bootloader[0m
[0;32mI (28) boot: compile time 13:10:30[0m
[0;32mI (32) boot: Enabling RNG early entropy source...[0m
[0;32mI (33) boot: SPI Speed : 40MHz[0m
[0;32mI (38) boot: SPI Mode : DIO[0m
[0;32mI (42) boot: SPI Flash Size : 4MB[0m
[0;32mI (46) boot: Partition Table:[0m
[0;32mI (49) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (57) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (64) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (71) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (79) boot: End of partition table[0m
[0;32mI (83) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x04bd4 ( 19412) map[0m
[0;32mI (99) esp_image: segment 1: paddr=0x00014bfc vaddr=0x3ffc0000 size=0x01ef4 ( 7924) load[0m
[0;32mI (104) esp_image: segment 2: paddr=0x00016af8 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (110) esp_image: segment 3: paddr=0x00016f00 vaddr=0x40080400 size=0x07e0c ( 32268) load[0m
[0;32mI (132) esp_image: segment 4: paddr=0x0001ed14 vaddr=0x400c0000 size=0x00000 ( 0) load[0m
[0;32mI (132) esp_image: segment 5: paddr=0x0001ed1c vaddr=0x00000000 size=0x012f4 ( 4852) [0m
[0;32mI (140) esp_image: segment 6: paddr=0x00020018 vaddr=0x400d0018 size=0x13078 ( 77944) map[0m
[0;32mI (181) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (181) boot: Disabling RNG early entropy source...[0m
[0;32mI (182) cpu_start: Pro cpu up.[0m
[0;32mI (185) cpu_start: Starting app cpu, entry point is 0x40080e38[0m
[0;32mI (178) cpu_start: App cpu up.[0m
[0;32mI (196) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (203) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM[0m
[0;32mI (209) heap_init: At 3FFC2700 len 0001D900 (118 KiB): DRAM[0m
[0;32mI (215) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM[0m
[0;32mI (221) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (228) heap_init: At 4008820C len 00017DF4 (95 KiB): IRAM[0m
[0;32mI (234) cpu_start: Pro cpu start user code[0m
[0;32mI (252) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
Hello world!
This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 4MB external flash
Restarting in 10 seconds...
Restarting in 9 seconds...
Restarting in 8 seconds...
Restarting in 7 seconds...
Restarting in 6 seconds...
Restarting in 5 seconds...
Restarting now.
Under windows you have to enable your console (cmd.exe or powershell) to be able to display those ANSI codes with a setting. One way to do this is by creating or setting the registry key VirtualTerminalLevel (DWORD) at [HKEY_CURRENT_USER\Console] to value 1.
See: Colored text output in PowerShell console using ANSI / VT100 codes
After that you can call the monitor with pio device monitor --raw and the coloring should work.
Has anyone tried, just for fun, to say monitor_port = --raw /dev/ttyACM0 ? If it’s just a copy-paste thing from this option line, that might actually construct the correct command string…
I have just tried that unsuccessfully in a few different combinations with different options (monitor-speed, monitor-port, etc.). When PIO parses the ini-file it always catches those “injection” attempts. could not open port '--raw COM3': could not open port '--raw COM3':
or ValueError: invalid literal for int() with base 10: '--raw'
Hello!
I was glad when I found out about the support for displaying colored text on the monitor.
Followed the recommendation above (I have Windows 10) created key the VirtualTerminalLevel (DWORD) at [HKEY_CURRENT_USER \ Console] with a value of 1.
Inserted to platformio.ini:
monitor_flags=
--echo
--raw
Rebooted the system. To when I activate the monitor, I see this:
> Executing task: C:\Users\Alexander\.platformio\penv\Scripts\platformio.exe device monitor <
Looking for advanced Serial Monitor with UI? Check http://bit.ly/pio-advanced-monitor
I haven’t tried setting the flags via monitor_flags yet, but why do you have listed --echo there? It also seems kinda weird to me, that the executed command doesn’t show the additional flags.
My English is only through Google translator. Please explain what do you mean?
What data still needs to be provided to prove that when the “ONLY MONITOR” is activated, it does not work properly (even if all the monitor flags are turned off).
What exactly is the environment you are using this in? Are you using VSCode? What are you doing exactly, when you say
and
I can’t reproduce this error using VSCode + PIO IDE. Manually starting the monitor with pio device monitor --raw results in the same output as launching the Serial Monitor with the “PlatformIO: Serial Monitor” button at the bottom of the VSCode window with monitor_flags beeing set to --raw.
