Hello everyone,
I’m trying to add “std::placeholders” namespace in my code to use “std::bind”, but I get following error:
error: 'placeholders' is not a namespace-name
I’ve been trying a lot of things and looking for the solution on internet for hours without success.
I created a new project and I got the same error.
This empty project has the basic code and the basic configuration.
Code:
using namespace std::placeholders;
platfomio.ini:
[env:az-delivery-devkit-v4]
board = az-delivery-devkit-v4
I found on another post that “std::placeholders” is available from C++11 version.
To check it, I cleaned and compiled the project again using “verbose build” and I checked that “-std=gnu++11” was present as a compiler argument.
So, now that I have reduce the problem to a empty project and a basic configuration, I don’t know what else I could check.
As additional information, I also checked I’m using the last Platformio version (v2.5.5), and I use it on Windows 10.
Any ideas? Thank you!
SOLUTION:
Hello, I replay myself as I finally managed to find out how to use std::bind properly.
I leave here this just if it can help someone.
The solution was very simple: instead of adding “using namespace std::placeholders” at the begining of the file, it should be added after the “includes”.
And, acording so some pleople, best if it’s used in a local scope inside the corresponding function.
So I added it before the lines where “std::bind” is used.
The code would be like follows. I use it inside a class to asign two methods to two callbacks one with two ints as parameters, and the other without parameters:
// Constructor of "ClassA". "Class A" is derived from "BaseClass"
DerivedClass::DerivedClass():BaseClass()
// Base class callback asignations using "std::bind"
// First callback on base class (two int parameters, returns void)
Callback1Base = std::bind(&DerivedClass::Function1, this, _1, _2);
// Second callback on base class (no parameters, returns void)
Callback2Base= std::bind(&DerivedClass::Function2, this);
void DerivedClass::Function1(int a, int b){
void DerivedClass::Function2(){
Why is the using declaration before the include? It doesn’t know anythnig about the std::placeholder namespace at that point…
You are right, that was the mistake.
I found some people recommend just not to use “using”. So, because of that, I added it inside the function as a local scope instead of a global scope.
