Read the Arduino MPU6050 documentation correctly (I’m sure I have) and include the necessary library files. The documentation for this doesn’t explain you have to add the I2CDevice and BusIO Libraries, which for a beginner turns out a tad frustrating.
CHANGED the ‘Basic readings’ example file to:
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
#include <Adafruit_I2CDevice.h>
#include <Adafruit_BusIO_Register.h>
#define I2C_ADDRESS 0x68
Adafruit_I2CDevice i2c_dev = Adafruit_I2CDevice(I2C_ADDRESS);
void setup(void)
while (!Serial)
delay(10);
Serial.println(“I2C device register test”);
if (!i2c_dev.begin()) {
Serial.print(“Did not find device at 0x”);
Serial.println(i2c_dev.address(), HEX);
while (1);
Serial.print(“Device found on address 0x”);
delay(5000);
/* while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println(“Adafruit MPU6050 test!”);
// Try to initialize!
if (!mpu.begin()) {
Serial.println(“Failed to find MPU6050 chip”);
while (1) {
delay(10);
Serial.println(“MPU6050 Found!”);
mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
Serial.print("Accelerometer range set to: ");
switch (mpu.getAccelerometerRange()) {
case MPU6050_RANGE_2_G:
Serial.println(“±2G”);
break;
case MPU6050_RANGE_4_G:
Serial.println(“±4G”);
break;
case MPU6050_RANGE_8_G:
Serial.println(“±8G”);
break;
case MPU6050_RANGE_16_G:
Serial.println(“±16G”);
break;
} delay(5000;
mpu.setGyroRange(MPU6050_RANGE_500_DEG);
Serial.print("Gyro range set to: ");
switch (mpu.getGyroRange()) {
case MPU6050_RANGE_250_DEG:
Serial.println(“± 250 deg/s”);
break;
case MPU6050_RANGE_500_DEG:
Serial.println(“± 500 deg/s”);
break;
case MPU6050_RANGE_1000_DEG:
Serial.println(“± 1000 deg/s”);
break;
case MPU6050_RANGE_2000_DEG:
Serial.println(“± 2000 deg/s”);
break;
} delay(5000);
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
Serial.print("Filter bandwidth set to: ");
switch (mpu.getFilterBandwidth()) {
case MPU6050_BAND_260_HZ:
Serial.println(“260 Hz”);
break;
case MPU6050_BAND_184_HZ:
Serial.println(“184 Hz”);
break;
case MPU6050_BAND_94_HZ:
Serial.println(“94 Hz”);
break;
case MPU6050_BAND_44_HZ:
Serial.println(“44 Hz”);
break;
case MPU6050_BAND_21_HZ:
Serial.println(“21 Hz”);
break;
case MPU6050_BAND_10_HZ:
Serial.println(“10 Hz”);
break;
case MPU6050_BAND_5_HZ:
Serial.println(“5 Hz”);
break;
Serial.println(“”);
delay(100);
void loop()
/* Get new sensor events with the readings */
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
/* Print out the values */
Serial.print(“Acceleration X: “);
Serial.print(a.acceleration.x);
Serial.print(”, Y: “);
Serial.print(a.acceleration.y);
Serial.print(”, Z: “);
Serial.print(a.acceleration.z);
Serial.println(” m/s^2”);
Serial.print(“Rotation X: “);
Serial.print(g.gyro.x);
Serial.print(g.gyro.y);
Serial.print(g.gyro.z);
Serial.println(” rad/s”);
Serial.print(“Temperature: “);
Serial.print(temp.temperature);
Serial.println(” degC”);
Serial.println(“”);
delay(1000);
- Which now works BUT…
mpu.setAccelerometerRange(MPU6050_RANGE_8_G); Does NOT set to 8G it’s 16G?
mpu.setGyroRange(MPU6050_RANGE_500_DEG); Does NOT set to 500DEG it’s 2000DEG?
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ); Does NOT set anything?
Any help very much appreciated.
