[Solved] Native AVR code linker error in Platformio, not Atmel studio
Really loving Platformio IDE, running into linker error in PlatformIO 2.000-beta3
Throwing linker errors similar to
Linking .pioenvs/native_avr/firmware.elf
 `rx1_buffer' referenced in section `.text' of /var/folders/rv/4zb74pz12t1970l_8mwwv0sr0000gr/T//ccZbpPSV.ltrans1.ltrans.o: defined in discarded section `COMMON' of .pioenvs/native_avr/src/usart.o (symbol from plugin)
Links fine in Atmel Studio 7.0.1417.
platformio.ini is
[env:native_avr]
board = atmega328pb
Any ideas?
Could you provide a simple test project to reproduce this issue?
Looks like this is a gcc linker/version issue, which can be worked around by adding
__attribute__((used))
after the problem variable definition;
eg
char rx0_buffer[RX0_BUFFER_SIZE] ;
becomes
char rx0_buffer[RX0_BUFFER_SIZE] __attribute__((used));
