Hi
I am getting this compiler error in one of the built-in files (variant.cpp) when building a trivial Hello World program. I am only getting it for the SAM/Due platform and not for the AVR/Uno platform.
Does anyone know if there is some simple work-around I could use here, or do I need to wait for an upstream bugfix?
This issue looks very similar to this one: Illegal Instruction [.pio/build/teensy40/src/main.cpp.o] Error 132 - #17 by maxgerhardt
Here is the console output (I am using the CLI):
pi@raspberrypi:~/Documents/RHex_Barebones $ pio run -e due -v
Processing due (platform: atmelsam; board: due; framework: arduino; monitor_speed: 115200)
CONFIGURATION: https:// docs.platformio. org/page/boards/atmelsam/due.html
PLATFORM: Atmel SAM (5.1.1) > Arduino Due (Programming Port)
HARDWARE: AT91SAM3X8E 84MHz, 96KB RAM, 512KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink, stlink)
- framework-arduino-sam 1.6.12
- framework-cmsis 1.40500.0 (4.5.0)
- framework-cmsis-atmel 1.2.0
LDF: Library Dependency Finder → http:// bit. ly/configure-pio-ldf
Found 3 compatible libraries
Scanning dependencies…
arm-none-eabi-g++ -o .pio/build/due/FrameworkArduinoVariant/variant.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50004 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E “-DUSB_PRODUCT="Arduino Due"” -DUSB_MANUFACTURER="Arduino" -DARDUINO_ARCH_SAM -I/home/pi/.platformio/packages/framework-arduino-sam/cores/arduino -I/home/pi/.platformio/packages/framework-arduino-sam/system/libsam -I/home/pi/.platformio/packages/framework-arduino-sam/system/CMSIS/CMSIS/Include -I/home/pi/.platformio/packages/framework-arduino-sam/system/CMSIS/Device/ATMEL -I/home/pi/.platformio/packages/framework-arduino-sam/variants/arduino_due_x /home/pi/.platformio/packages/framework-arduino-sam/variants/arduino_due_x/variant.cpp
/home/pi/.platformio/packages/framework-arduino-sam/variants/arduino_due_x/variant.cpp: In function ‘void init()’:
/home/pi/.platformio/packages/framework-arduino-sam/variants/arduino_due_x/variant.cpp:451:1: internal compiler error: Illegal instruction
Please submit a full bug report,
with preprocessed source if appropriate.
See for instructions.
*** [.pio/build/due/FrameworkArduinoVariant/variant.cpp.o] Error 1
========== [FAILED] Took 22.11 seconds =============================Environment Status Duration
uno IGNORED
due FAILED 00:00:22.111
=========== 1 failed, 0 succeeded in 00:00:22.111 ========
Here is my source file:
void setup()
Serial.println ( “Hello World!” );
}void loop()
delay(1000);
Serial.println ( “Beep!” );
Here is my platform.ini
[env:uno]
board = uno
monitor_speed = 115200[env:due]
platform = atmelsam
board = due
Here is the pio system info:
pi@raspberrypi:~/Documents/RHex_Barebones $ pio system info
PlatformIO Core 5.0.4
Python 3.7.3-final.0
System Type linux_armv6l
Platform Linux-5.4.83±armv6l-with-glibc2.28
File System Encoding utf-8
Locale Encoding UTF-8
PlatformIO Core Directory /home/pi/.platformio
PlatformIO Core Executable /home/pi/.platformio/penv/bin/platformio
Python Executable /home/pi/.platformio/penv/bin/python
Global Libraries 0
Development Platforms 4
Tools & Toolchains 12
