Hi everyone,
I’m new with PlatformIO, I’ve started to used it just to try a better alternative to Arduino IDE.
I’ve been testing and working with a ESP8266 module some like this (https://www.ebay.com/itm/ESP8266-ESP-01S-Serial-WIFI-Wireless-Module-Adapter-Breakout-Send-Receive-AP-STA-/123085771963?hash=item1ca87bd4bb).
I’ve been flashing new code (scketchs from Arduino) using the Arduino IDE, and it was good… without problems (I’m using a FTDI module and an small and easy circuit to connect the ESP8266 to may PC).
Recently, I wanted to upload the code written into Platformio, but after to flash it nothing happens… I’ve tested with a very simple Blink code (using the BUILTIN led)… I only see this in the serial monitor (also setting differents velocities 9600, 115200, etc):
--- Miniterm on /dev/ttyUSB0 74880,8,N,1 ---
I only see a lot of " ␀ "…
Anyway if I flash the same code from Arduino IDE, it works.
Let me show the Arduino output:
Archiving built core (caching) in:
/tmp/arduino_cache_293123/core/core_esp8266_esp8266_generic_CpuFrequency_80,
ResetMethod_ck,
CrystalFreq_26,
FlashFreq_40,
FlashMode_qio,
FlashSize_512K0,
led_2,
LwIPVariant_v2mss536,
Debug_Disabled,
DebugLevel_None____,
FlashErase_none,
UploadSpeed_115200_0070b685019b66ed4c542f40904ccc4b.a
Sketch uses 246259 bytes (49%) of program storage space. Maximum is 499696 bytes.
Global variables use 32224 bytes (39%) of dynamic memory, leaving 49696 bytes for local variables. Maximum is 81920 bytes.
Uploading 250400 bytes from /tmp/arduino_build_479072/Blink.ino.bin to flash at 0x00000000
And it’s the output from platformio:
PLATFORM: Espressif 8266 > Espressif Generic ESP8266 ESP-01 512k
SYSTEM: ESP8266 80MHz 80KB RAM (512KB Flash)
LDF MODES: FINDER(chain) COMPATIBILITY(light)
Collected 26 compatible libraries
Compiling .pioenvs/esp01/src/main.cpp.o
Archiving .pioenvs/esp01/libFrameworkArduinoVariant.a
Indexing .pioenvs/esp01/libFrameworkArduinoVariant.a
Compiling .pioenvs/esp01/FrameworkArduino/Esp-version.cpp.o
Compiling .pioenvs/esp01/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/esp01/FrameworkArduino/umm_malloc/umm_malloc.c.o
Archiving .pioenvs/esp01/libFrameworkArduino.a
Indexing .pioenvs/esp01/libFrameworkArduino.a
Linking .pioenvs/esp01/firmware.elf
Checking program size
text data bss dec hex filename
255636 3108 29992 288736 467e0 .pioenvs/esp01/firmware.elf
Building .pioenvs/esp01/firmware.bin
Looking for upload port...
Auto-detected: /dev/ttyUSB0
Uploading .pioenvs/esp01/firmware.bin
Uploading 262896 bytes from .pioenvs/esp01/firmware.bin to flash at 0x00000000
I’ve used differents setups into “platformio.ini” but I always got the same result the code is flashed successfully but nothing happens.
For example the last configuration that I’ve tried was:
[env:esp01]
platform = espressif8266
board = esp01
board_flash_mode = qio
; set frequency to 40MHz
board_f_flash = 40000000L
upload_resetmethod = ck
upload_speed = 115200
So, do you have any ideas about what I’m doing wrong? or what am I missing?
Thanks
