I have a strange problem when compiling to two targets.
If I change the order of adding the environment to platformio.ini, then the error occurs in the second target (alternating).
At the same time it manages to compile and link only one target.
macOS 10.12.5, Atom and Platformio Uptodate.
Platformio.ini file:
[platformio]
src_dir = dragon
[env:esp12e]
platform = espressif8266
board = esp12e
[env:ESP32]
platform = espressif32_stage
build_flags = -Wl, -DMQTT_MAX_PACKET_SIZE=512
lib_deps = PubSubClient
Error:
[Thu Apr 13 07:39:35 2017] Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
Converting main.ino
Collected 29 compatible libraries
Looking for dependencies...
Library Dependency Graph
|-- <ESP8266WiFi> v1.0
|-- <RCSwitch> v2.52
|-- <PubSubClient> v2.6
Compiling .pioenvs/esp12e/src/main.ino.o
Calculating size .pioenvs/esp12e/firmware.elf
text data bss dec hex filename
231012 3404 30040 264456 40908 .pioenvs/esp12e/firmware.elf
========================= [SUCCESS] Took 1.37 seconds =========================
[Thu Apr 13 07:39:37 2017] Processing ESP32 (platform: espressif32_stage; lib_deps: PubSubClient; build_flags: -Wl, -DMQTT_MAX_PACKET_SI
ZE=512; board: esp32dev; framework: arduino)
Converting main.ino
Collected 19 compatible libraries
|-- <RCSwitch> v2.52
|-- <WiFi> v1.0
Compiling .pioenvs/ESP32/src/main.ino.o
Linking .pioenvs/ESP32/firmware.elf
/Users/jkk/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld: cannot fin
d : No such file or directory
PIO Buildplatformio.ini00020:1
LFUTF-8INI
