Hi guys,
Please, help to change default partitioning of the Flash in 4MB ESP-WROOM-32 to:
- 3MB for the firmware with OTA;
- 1MB for the SPIFFS.
For the ESP8266 modules I used one of these lines in platformio.ini:
board_build.ldscript = eagle.flash.4m1m.ld
or
build_flags = -Wl,-Teagle.flash.4m1m.ld
However, for the ESP32 this throws:
.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot open linker script file eagle.flash.4m1m.ld: No such file or directory
My current platformio.ini is:
[env:wemosbat]
board = wemosbat
lib_deps = marvinroger/Homie@^3.0.1
Any idea is appreciated.
UPDATE:
This line in platformio.ini addresses my needs pretty well:
board_build.partitions = min_spiffs.csv
This keeps almost 2MB for each OTA bank and 190KB for the SPIFFS. This is good enough for my case.
