Hello there! Sorry if this is newbie question but I’ve not been able to find a solution that works for me when searching a lot on this issue.
I have an Arduino project that I’m now going to split into multiple class files to improve the structure. However, when I try to compile I get the famous “undefined reference to '…” error.
To make this as short as possible I’ve created a new d1_mini Arduino project from scratch in PlatformIO on Visual Studio Code. Using the IDE (right click/“new file”) I’ve added to files to the src folder; SlowPinPWM.h and SlowPinPWM.cpp. The contents in the files are:
SlowPinPWM.h:
#ifndef SlowPinPWM_h
#define SlowPinPWM_h
#include “Arduino.h”
class SlowPinPWM
public:
SlowPinPWM(byte pinNumber);
void hello();
private:
SlowPinPWM.cpp:
#include “SlowPinPWM.h”
SlowPinPWM::SlowPinPWM(byte pinNumber) {
void hello() {
Serial.println(“Hello”);
and finally main.cpp:
SlowPinPWM boiler(1);
boiler.hello();
I have not made any changes to platformio.ini, this is all:
[env:d1_mini]
platform = espressif8266
board = d1_mini
When I compile I get:
Processing d1_mini (platform: espressif8266; board: d1_mini; framework: arduino)
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Espressif 8266 > WeMos D1 R2 & mini
HARDWARE: ESP8266 80MHz 80KB RAM (4MB Flash)
Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Collected 36 compatible libraries
Scanning dependencies…
Linking .pioenvs\d1_mini\firmware.elf
.pioenvs\d1_mini\src\main.cpp.o:(.text.setup+0x4): undefined reference to SlowPinPWM::hello()'** **.pioenvs\d1_mini\src\main.cpp.o: In function
setup’:
main.cpp:(.text.setup+0x10): undefined reference to `SlowPinPWM::hello()’
*** [.pioenvs\d1_mini\firmware.elf] Error 1
========================================= [ERROR] Took 2.53 seconds =========================================
I’ve tried to add library and build options in platformio.ini but nothing helps. What am I doing wrong?
Best regards,
Per
