Yesterday I upgraded my laptop to Linux Mint21 and today I couldn’t upload code to my Uno (or other) boards from PlatformIO and from the Arduino IDE. I did all of the following:
- Updated my udev rules and restarted udev.
- Checked I was still in upload and dialout groups.
- Added
upload_port
toplatformio.ini
To no avail. Plugging in my Uno normally gives am a /dev/ttyUSB0
device file, but on Mint 21, this was not the case.
Running dmesg --follow
I got this:
[ 833.816734] usb 3-2.3.4: new full-speed USB device number 9 using xhci_hcd
[ 833.942762] usb 3-2.3.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[ 833.942771] usb 3-2.3.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 833.942774] usb 3-2.3.4: Product: USB2.0-Serial
[ 833.951868] ch341 3-2.3.4:1.0: ch341-uart converter detected
[ 833.952865] usb 3-2.3.4: ch341-uart converter now attached to ttyUSB0
[ 834.477846] input: BRLTTY 6.4 Linux Screen Driver Keyboard as /devices/virtual/input/input30
[ 834.598088] usb 3-2.3.4: usbfs: interface 0 claimed by ch341 while 'brltty' sets config #1
[ 834.598667] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[ 834.598681] ch341 3-2.3.4:1.0: device disconnected
[ 945.437544] usb 3-2.3.4: USB disconnect, device number 9
Which gives the information that my board was connecvted to /dev/ttyUSB0
but then disconnected. Hmmm. The culprit is this:
Something called brltty
is claiming my Uno’s interface. (Or something like that!) So, a quick hunt and it turns out that Linux Mint 21 installs brltty
which is a braille terminal for visually impared people. As I’m not yet visually impaired, I only need reading glasses (so far!) I can remove it:
sudo apt remove brltty
Now dmesg
gives me this:
[ 955.157650] usb 3-2.3.4: new full-speed USB device number 10 using xhci_hcd
[ 955.283692] usb 3-2.3.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[ 955.283701] usb 3-2.3.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 955.283704] usb 3-2.3.4: Product: USB2.0-Serial
[ 955.292350] ch341 3-2.3.4:1.0: ch341-uart converter detected
[ 955.293220] usb 3-2.3.4: ch341-uart converter now attached to ttyUSB0
And no disconnect.
PlatformIO and the Arduino IDE can both now see /dev/ttyUSB0
as an available port.
HTH
Cheers,
Norm.
