I’m working on getting Software Serial working on an L4R5ZI nucleo devboard, and running into a few issues. Transmitting data works perfectly using <SoftwareSerial.h>, but receiving is not working for me.
When I switch the device to using HardwareSerial and change its port to the RX for UART3 for example, everything works just fine, it’s only when I switch to softwareserial where I have issues.
While the nucleo board has plenty of hardware serial options, I will not have those available to me in the final design since we will be using a STM32L412k instead of a STM32L4R5Z.
The applicable parts of my code:
#include "SoftwareSerial.h"
SoftwareSerial Sensor1Serial(D4, SENSOR_NULL_PIN); // the MCU does not need to transmit anything over UART so passing null as TX pin. I have tested with an actual pin here, still no luck on receiving on the devboard
Sensor1Serial.begin(9600);
while(!Sensor1Serial.available()) { }
while(Sensor1Serial.available()) {
data += (char)Sensor1Serial.read();
if(Sensor1Serial.read() == kEndOfDataStream) { // 0x0D signifies end of data
break;
Not quite sure what you mean - I’ve been using the VSCode extension for building/uploading.
Everything builds/uploads fine, but the first while loops forever when Sensor1Serial is type SoftwareSerial.
I want to make sure that the problem you’re seeing is not specific to PlatformIO, but to the STM32Duino Arduino core (in which case it’s an immediate bug report to the Arduino core and not here at PlatformIO). You should grab the Arduino IDE 1.8.16 as normal at https://www.arduino.cc/en/software, install the STM32Duino core, select the same board you selected in PlatformIO and give it the exact same code snippet you gave PlatformIO, then upload and test.
My first suspect would be the pin choice. You use “D4” for RX. As a test, you could remove anything attached, set that pin up as digital output, make it blink slowly, and verify with an LED or voltmeter.
Pin names can be very confusing across the STM32 / Arduino / PlatformIO worlds - “D4” is most likely an Arduino designation, whereas “PD4” is an STM32 GPIO name. They differ. Another pin number interpretation difference could be between h/w and s/w serial.
And lastly: I suspect that SoftwareSerial relies on EXTI pin interrupts, so the question is whether SoftwareSerial supports (and properly configures) that on the particular pin you’re using.
As for your suggestion @jcw - D4 appears to be functioning properly as both a simple digital output and input. Do you think that it could just be D4 specifically and it would make sense to go through a few other GPIO to attempt to find one that works? Or do you have a recommendation for which ones to try?
So the usage of D4 or PF14 in the code should be exactly interchangable.
I’m not sure whether there’s a technical liminitation regarding the EXTI on PF14, which would map to EXTI14. Maybe it’s already occupied by some other code in the sketch or in framework code which you don’t see? If I remember STM32 hardware restrictions correctly, any Px14 pin (PA14, PB14, …) will occupy the EXTI14 peripheral (when using GPIO interrupts), and thus using attachInterrupt() etc on any of those pins might interfer with the ability to do a software-serial RX on PF14.
The piece of code you’re testing only creates the software serial devices and prints all received characters out to the main serial?
Should have gone to a minimal program sooner. Getting the expected data back. Here’s that code:
#include <SoftwareSerial.h>
SoftwareSerial sensorSerial(D4, NULL);
sensorSerial.begin(1200);
Serial.begin(9600);
while(!sensorSerial.available()) {
while(sensorSerial.available()) {
Serial.print((char)sensorSerial.read());
So I’m guessing this is pointing to that there is something else in my existing firmware causing a conflict of some sort or disabling the EXTI somehow. I’m currently using pins D1 (PD8), D0 (PD9), PC12, PD2, PA11, PA12, PA0, PA1, PB1, PB4, PB5, PB6, and PB7.
Mhm NULL is not a good argument in this since it will evaluate to numeric 0 which is interpreted as the zeroeth pin, so PD9, which is used as you say… The macros used here by their logic support -1 as a value, which will evalute to NC (not connected) in functions used later. Does it make a difference if you write -1 instead of NULL in the sketch that is non working? Does it make a difference if you use D4 as both TX & RX pin in the constructor?
Gotcha. I just tried using -1 in the working minimal program and RX on sensorSerial no longer worked as expected. Defining both TX and RX also caused the RX to not work.
Whee, Max digs in deep and gets results, as usual …
That was my next thought: a conflicting EXTI config elsewhere.
So IMO it’s either a that, or the Tx NULL/-1 choice - or both.
Perhaps you can pick two other pins (even if Tx never sends).
Note that s/w-based serial Rx is quite tricky, in terms of IRQs & timing.
I think you’ve narrowed it down correctly - when I changed PD9 which was in use to another pin, now SoftwareSerial sensorSerial(D4, NULL); works correctly. But as you said this prevents the use of PD9. I’ll find some pins that won’t be in use and give it a shot.
Using pins PE12, PE14, and PE15 as TX pins, I am receiving data on my RX pins in the main firmware. Everything is fully working now.
I second this - Max you’re amazing! Thanks for all your help guys.
