After updating, my Windows 10 Pro to the 2004 update from Microsoft my complies went from about 4 mins to 45+ mins. Nothing has changed with my project. Same setup as before the 2004 update. Anyone else run into this
The fix is probably to remove Windows
Seriously though, I’d probably check if Windows Defender is doing anything nasty… Exploit protection was something causing grief in the past. Maybe do a compile with Task manager open and see what’s hogging the CPU / disk.
I had the exact same issue, even after turning off Windows Defender in various ways. Turns out there was another security program, Trusteer / Rapport that was interfering. After it was uninstalled, builds got very fast.
Mine ended up being the windows update. I downloaded a preview of the next update and fix this problem plus a couple of othwrs
