I want to arrange files of a simple firmware project in the following way:
├── drivers
│ ├── ads1256.cpp
│ ├── ads1256.h
│ ├── ads1256_regmap.h
│ ├── tlc59208.cpp
│ └── tlc59208.h
├── app
│ ├── assert.cpp
│ ├── assert.h
│ ├── command.cpp
│ ├── command.h
│ ├── led.cpp
│ ├── led.h
│ └── main.cpp
├── test
│ └── test_ads1256.cpp
│ └── test_tlc59208.cpp
└── platformio.ini
But by default, PlatformIO assumes a more… nested file organization for libs/
and tests/
, requiring a subdirectory for each library or test. How can I achieve this simpler, flatter structure for small projects?
I know I can come close to the desired structure by using lib_extra_dirs = drivers
and putting each driver in a dedicated subdir + also tests need to be in a dedicated subdir each… but, do I really NEED to?
And an more philosophical/educational subquestion: why wouldn’t I want to do this kind of file layout in smal projects? Why is the one-subdirectory-per-lib preferred?
