lnelson
December 12, 2020, 1:13am
#1
I’m new to both PlatformIO and vscode, so my question may be silly. I come from a world where emacs and make were my IDE.
I’m running the 64-bit version of Raspberry Pi OS, so I’m not surprised that PlatformIO can’t find a simavr package for linux_aarch64. However, I do have simavr installed and working on the system. Is there a way to convince PlatformIO to use the system’s simavr?
My platformio.ini:
[env]
board = pro16MHzatmega328
fastled/FastLED@^3.3.3
thomasfredericks/Bounce2@^2.55
deanisme/SevSeg@^3.4.0
platform_packages = toolchain-atmelavr@>=1.70300.0
upload_protocol = custom
upload_port = usb
upload_flags =
-vvv
-C
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
avrispmkii
[env:328p]
[env:simavr]
debug_tool = simavr
[env:serialdebug]
build_flags = -D serialdebug
As a workaround, can you please:
download the Linux x64 version tar archive from Service End for Bintray, JCenter, GoCenter, and ChartCenter | JFrog
extract it in ~/.platformio/packages/
on the pi so that all the files are in the ~/.platformio/packages/tool-simavr
folder
in the package.json
, replace linux_x86_64
with linux_aarch64
remove the old binaries and libs, bin/simavr
and lib/libsimavr.{a,so,so.1}
and replace them with the correct bins/libs of your native system (best to copy, not to symlink)
run pio package pack
inside ~/.platformio/packages/tool-simavr
and backup the resulting .tar.gz
rerun debugging and check if it now finds simavr
If that works it means you’ve created a functional tool-simavr
package for aarch64. The .tar.gz
file can then be used for distribution / reuse on other computers of the same arch, by adding
platform_packages =
tool-simavr@file://<filepath to .tar.gz file>
in the platformio.ini
of the project and a provided path to the tool’s tar archive. (docs )
lnelson
December 13, 2020, 9:03am
#3
So far, I’m still getting the same error, so I’ve probably done something wrong or maybe there’s a version mismatch?
The directory:
00:56:28 rpi07 lnelson:~/.../packages/tool-simavr> pwd
/home/lnelson/.platformio/packages/tool-simavr
00:56:29 rpi07 lnelson:~/.../packages/tool-simavr> tree
|-- bin
| `-- simavr
|-- include
| `-- simavr
| |-- avr
| | `-- avr_mcu_section.h
| |-- avr_acomp.h
| |-- avr_adc.h
| |-- avr_bitbang.h
| |-- avr_eeprom.h
| |-- avr_extint.h
| |-- avr_flash.h
| |-- avr_ioport.h
| |-- avr_lin.h
| |-- avr_spi.h
| |-- avr_timer.h
| |-- avr_twi.h
| |-- avr_uart.h
| |-- avr_usb.h
| |-- avr_watchdog.h
| |-- fifo_declare.h
| |-- sim_avr.h
| |-- sim_avr_types.h
| |-- sim_cmds.h
| |-- sim_core.h
| |-- sim_core_config.h
| |-- sim_core_decl.h
| |-- sim_cycle_timers.h
| |-- sim_elf.h
| |-- sim_gdb.h
| |-- sim_hex.h
| |-- sim_interrupts.h
| |-- sim_io.h
| |-- sim_irq.h
| |-- sim_network.h
| |-- sim_regbit.h
| |-- sim_time.h
| |-- sim_utils.h
| `-- sim_vcd_file.h
|-- lib
| |-- libsimavr.a
| |-- libsimavr.so -> libsimavr.so.2
| |-- libsimavr.so.2
| |-- libsimavrparts.a
| |-- libsimavrparts.so -> libsimavrparts.so.1
| |-- libsimavrparts.so.1
| `-- pkgconfig
| |-- simavr-avr.pc
| `-- simavr.pc
`-- package.json
package.json:
00:56:30 rpi07 lnelson:~/.../packages/tool-simavr> cat package.json
"name": "tool-simavr",
"version": "1.10600.200511",
"description": "simavr is a lean, mean and hackable AVR simulator",
"keywords": [
"simulator",
"avr",
"microchip"
"license": "GPL-3.0-or-later",
"system": [
"linux_aarch64"
"repository": {
"type": "git",
"url": "https://github.com/buserror/simavr"
T platform.ini:
01:01:51 rpi07 lnelson:~/src/ChristmasLights2020> cat platformio.ini
[env]
tool-simavr @ file:///home/lnelson/tool-simavr-linux_aarch64-1.10600.200511.tar.gz
upload_port = usb
upload_flags =
-vvv
-C
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
avrispmkii
[env:328p]
[env:simavr]
debug_tool = simavr
[env:serialdebug]
build_flags = -D SERIALDEBUG
What error exactly please?
That looks wrongly formatted, should be
platform_packages =
lnelson
December 13, 2020, 7:09pm
#5
Oops, forgot the error. Boneheaded move on my part. Sorry.
Error: Could not find the package with 'platformio/tool-simavr @ ~1.10600.200511' requirements for your system 'linux_aarch64'
The installed deb package is simavr_1.6+dfsg-1_arm64.deb
from which I copied the libs and executable.
I fixed the formatting in platformio.ini. Thank you for that. However, I still get the same error mentioned above.
lnelson
December 13, 2020, 7:52pm
#6
I built simavr from the latest source on github and placed the new binary and libraries in ~/.platformio/packages/tool-simavr
. I update package.json and the package filename in platformio.ini to reflect the compiled version number. I still get the same error mentioned above. I compiled version 1.6 but platformio is still looking for ~1.10600.200511
platformio.ini:
[env]
platform_packages =
upload_port = usb
upload_flags =
-vvv
-C
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
avrispmkii
[env:328p]
[env:simavr]
debug_tool = simavr
[env:simavr_aarch64]
debug_tool = simavr
platform_packages =
tool-simavr @ file:///home/lnelson/tool-simavr-linux_aarch64-1.6.tar.gz
[env:serialdebug]
I use the environment simavr_aarch64
for this testing.
package.json:
"version": "1.6",
"keywords": [
"simulator",
"avr",
"microchip"
"system": [
"linux_aarch64"
"repository": {
"type": "git",
~/.platformio/packages/tool-simavr/
|-- bin
| `-- simavr
|-- include
| `-- simavr
| |-- avr
| |-- avr_acomp.h
| |-- avr_adc.h
| |-- avr_bitbang.h
| |-- avr_eeprom.h
| |-- avr_extint.h
| |-- avr_flash.h
| |-- avr_ioport.h
| |-- avr_lin.h
| |-- avr_spi.h
| |-- avr_timer.h
| |-- avr_twi.h
| |-- avr_uart.h
| |-- avr_usb.h
| |-- avr_watchdog.h
| |-- fifo_declare.h
| |-- sim_avr.h
| |-- sim_avr_types.h
| |-- sim_cmds.h
| |-- sim_core.h
| |-- sim_core_decl.h
| |-- sim_elf.h
| |-- sim_gdb.h
| |-- sim_hex.h
| |-- sim_interrupts.h
| |-- sim_io.h
| |-- sim_irq.h
| |-- sim_network.h
| |-- sim_regbit.h
| |-- sim_time.h
| |-- sim_utils.h
| `-- sim_vcd_file.h
|-- lib
| |-- libsimavr.a
| |-- libsimavr.so -> libsimavr.so.1
| |-- libsimavr.so.1
| |-- libsimavrparts.a
| `-- pkgconfig
| |-- simavr-avr.pc
| |-- simavr.pc
| `-- simavrparts.pc
`-- package.json
I haven’t made any changes in the include directory.
Seems like it’s dead-bent on first trying to install the package from the PlatformIO registry and then respecting the override in the PlatformIO. Can you please try the following:
Move the platform_packages
(for both packages) to env
(only have 1 such directive)
If that still fails, prepend platformio/
to the tool-simavr @ ..
(as the owner name of the package)
If that still fails, I would like to ask @valeros or @ivankravets to publish the missing tool-simavr
so that it’s just fixed globally
(yes, using pio account
and pio package publish
commands, you could also publish your tool-simavr-linux_aarch64-1.6.tar.gz
file and reference it in the platform.json
of ~/.platformio/platforms/atmelavr
, but then it’s still a local fix)
lnelson
December 13, 2020, 10:08pm
#8
Still no luck.
[env:default]
debug_tool = simavr
platform_packages =
upload_port = usb
upload_flags =
-vvv
-C
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
avrispmkii
Changing
to
platformio/tool-simavr @ file:///home/lnelson/tool-simavr-linux_aarch64-1.6.tar.gz
Makes no difference.
valeros
December 15, 2020, 1:43pm
#9
Unfortunately, there is no package for linux_aarch64
. It should work if you specify the folder with package.json
directly instead if an arhive:
platform_packages =
