Hello there,
I’m trying to do a little simulated testing for a Sparkfun Pro Micro system. I’m trying to get some automatic tests setup but I’ve hit a problem. I have a test that compiles up nicely, producing an elf and hex. When I execute ‘pio test --without-upload’, the testing hangs, saying “Testing…”
I’ve tried a couple of things. I downloaded the latest simavr and ran it against the elf that platformio created…
simavr -m atmega32u4 -f 16000000L -v .pio/build/sparkfun_promicro16/firmware.hex
I get the following:
Loaded 1 section of ihex
Load HEX flash 00000000, 4972
Looks like it’s placing the hex at the top of the memory block. Wouldn’t the bootloader normally be here? Perhaps simavr needs the sparkfun bootloader in addition to this hex? Not sure if this is the case. If it is, my question would be ‘how do I set this up in platformio?’.
However, I also tried the same test setup, but with an arduino uno, atmega328p and that worked absolutely fine, so perhaps the bootloader has nothing to do with it.
My current platformio.ini looks like this:
[env:sparkfun_promicro16]
board = sparkfun_promicro16
; change microcontroller
board_build.mcu = atmega32u4
; change MCU frequency
board_build.f_cpu = 16000000L ; or 8000000L if 8Mhz 3.3V version
upload_port = /dev/ttyACM*
bluerobotics/BlueRobotics MS5837 Library@^1.1.1
sparkfun/SparkFun ISL29125 Breakout@^1.0.1
adafruit/Adafruit BusIO@^1.14.1
lowpowerlab/LowPower_LowPowerLab@^2.2
RTClib
Wire ; Needed for test only for some reason?
SPI ; As above
platform_packages =
platformio/tool-simavr
test_speed = 38400 ; will this cause issues as we use 38400 baud?
-DSENSOR_TYPE=5 ;or SOUNDNET_V1_R5 in this case. Change depending on hardware version
-Werror
extra_scripts =
; pre:apply_patches.py
test_simulated.py
test_testing_command =
${platformio.packages_dir}/tool-simavr/bin/simavr
-m
atmega32u4
-f
8000000L
${platformio.build_dir}/${this.__env__}/firmware.elf
I thought perhaps the sparkfun stuff might not be quite right, so I also tried the test but for an arduino leonardo, which uses the same ATMega32U4. The same problem seems to occur. So this suggests something is wrong with simavr when used with the ATMega32U4.
I wonder, is this because of the USB part of this particular setup? Is it a permissions thing where the USB port can’t be created? I know the U4 has it’s own USB stack for this sort of thing. I’m running on Arch Linux so I thought, maybe try on Debian instead? Same trouble unfortunately.
Does anyone have any thoughts please? I figure I must have missed something.
Cheers
Ben
