I’m unable to scan my i2c device. I’m running the i2c scanner code on this board:
with no success, tried the same code same connections with esp32 and I do see my device. Any ideas?
Code:
#include <Wire.h>
// Initialise
Wire.begin(PB6,PB7);
// Setup monitor
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
platformio.ini:
[env:genericSTM32F401CC]
platform = ststm32
board = genericSTM32F401CC
upload_protocol = stlink
debug_tool = stlink
debug_speed = 5000
Connections:
3.3V
GND
PB6->SCL
PB7->SDA
