I have started to play with PlatformIO and have a working blinking LED in two projects, one with HAL, another with libopencm3.
Both of them use this to blink (so clock changes would be visible):
while(true) {
gpio_toggle(LEDPORT, LEDPIN); //Using API function gpio_toggle()
for (i = 0; i<1000000; i++)
asm(“nop”);
None of the projects sets the clock explicitly in main.c or elswhere. So I have tried to edit platform.ini:
board_build.f_cpu = 18000000L
build_flags = -D HSE_VALUE=12000000U
build_flags = -D SYS_CLOCK=12000000L
None of these settings changed the blinking frequency.
Is it possible to change the clock (PLL, divider, …) in HAL or libopencm3 projects? What am I doing wrong?
Thanks
Hi!
for libopencm3 use functions like
rcc_clock_setup_pll(&rcc_hse_25mhz_3v3[RCC_CLOCK_3V3_168MHZ]);
or configure pll manually with code
Thanks, that worked for libopencm3.
I will have to make own ‘rcc_hse’ define to set more options, but it’s straight forward.
static RCC_ClkInitTypeDef rccClkInstance =
.ClockType = RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2,
.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK,
.AHBCLKDivider = RCC_SYSCLK_DIV1,
.APB1CLKDivider = RCC_HCLK_DIV1,
.APB2CLKDivider = RCC_HCLK_DIV1,
static RCC_OscInitTypeDef clock_setup = {
.OscillatorType = RCC_OSCILLATORTYPE_HSE,
.HSEState = RCC_CR_HSEON,
.PLL = { //100MHz with external 25MHz quarz
.PLLState = RCC_PLL_ON,
.PLLSource = RCC_PLLSOURCE_HSE,
.PLLM = 25,
.PLLN = 400,
.PLLP = RCC_PLLP_DIV4,
void main()
HAL_Init();
if(HAL_RCC_OscConfig(&clock_setup) != HAL_OK) Error_Handler();
if(HAL_RCC_ClockConfig(&rccClkInstance, FLASH_LATENCY_2) != HAL_OK) Error_Handler();
works as initialisation using HAL manually (without using STM32CubeMX).
I was falsely thinking that PlatformIO configures the chip on it own, because of existing .ini flags.
