Greetings people.
I’m progamming an UNO R3 using a AVRISP mkII. The purpose of this exercise is I’m trying to learn about setting fuses for a barebones atmega328p.
I’m running PlatformIO, version 3.3.0 on a mac. platformio has been working wonderfully for quite a while with USB uploads to teensys and unos.
So the approach is create a directory called “boards” in the root directory of my project. Put in a manifest file, change the fuses, upload with the AVRISP. Here we go.
Make a boards directory, put a file in there called boards_test.json with the following:
"build": {
"core": "arduino",
"extra_flags": "-DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO",
"f_cpu": "16000000L",
"hwids": [
"0x2341",
"0x0043"
"0x2341",
"0x0001"
"0x2341",
"0x0243"
"0x2A03",
"0x0043"
"mcu": "atmega328p",
"variant": "standard"
"frameworks": [
"arduino",
"simba"
"fuses": {
"efuse": "0x05",
"hfuse": "0xDE",
"lfuse": "0xFF",
"lock": "0x3F"
"name": "board_test",
"upload": {
"maximum_ram_size": 2048,
"maximum_size": 32256,
"protocol": "arduino",
"require_upload_port": true,
"speed": 115200
"url": "https://www.arduino.cc/en/Main/ArduinoBoardUno",
"vendor": "Arduino"
Test if I can find it.
$ platformio boards | grep board_test
board_test ATMEGA328P 16Mhz 31kB 2kB board_test
no idea why I get three hits but there we go.
also in the root directory I have the following platformio.ino file:
# fuse testing
[env:board_test]
board = board_test
upload_protocol = stk500v2
upload_flags = -Pusb
So.
when I run: $ pio run --target program -v I get it to load. But changing the fuses in the manifest file does nothing. I figure, that’s because fuses has to be a target. So
$ pio run --target fuses -v
[Sun Sep 24 09:39:42 2017] Processing board_test (upload_protocol: stk500v2, platform: atmelavr, upload_flags: -Pusb, board: board_test, framework: arduino)
avr-g++ -o "/Users/owhite/uno/board_test/src/blink.ino.cpp" -x c++ -fpreprocessed -dD -E "/var/folders/p8/m441knk55_94tz2zwckt5mqr0000gp/T/tmpuSSXZi"
Collected 31 compatible libraries
Looking for dependencies...
Project does not have dependencies
BeforeUpload(["fuses"], [])
Auto-detected: /dev/cu.usbmodem1421
avrdude -v -p atmega328p -C /Users/owhite/.platformio/packages/tool-avrdude/avrdude.conf -c stk500v2 -Pusb -b 115200 -P "/dev/cu.usbmodem1421" -e -Ulock:w:0x3F:m -Uhfuse:w:0xDE:m -Uefuse:w:0x05:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
System wide configuration file is "/Users/owhite/.platformio/packages/tool-avrdude/avrdude.conf"
User configuration file is "/Users/owhite/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1421
Using Programmer : stk500v2
Overriding Baud Rate : 115200
and it hangs. I’m looking for suggestions of what to try next. And, wouldnt I want to be able to program and -then- set the fuses? Or should I just set the fuses and program?
On that topic, I tried having more than one target by using the .ini file. As in:
targets = program, fuses
or even
targets = program, clean
and it only handles the second target, it does not do both.
I have also tried the extra_script method as described here link
in that case the UNO had a bootloader, target = upload, but it did not change the fuses.
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
