I’m afraid that check is in the Arduino code. In the file USBCore.cpp
I see this:
// ATmega32U4
#if defined(PINDIV)
#if F_CPU == 16000000UL
PLLCSR |= (1<<PINDIV); // Need 16 MHz xtal
#elif F_CPU == 8000000UL
PLLCSR &= ~(1<<PINDIV); // Need 8 MHz xtal
#else
#error "Clock rate of F_CPU not supported"
Which implies that on this board, you need to have an 8 or 16 MHz crystal, and therefore, F_CPU
needs to match the hardware.
Can you not just set the prescaler according to the 8 or 16 MHz hardware clock in use? The data sheet at https://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-7766-8-bit-AVR-ATmega16U4-32U4_Datasheet.pdf shows that you can divide the 8/16 MHz crystal frequency by 1,2,4,8,16,32,64,128,or 256 to reduce power consumption.
Board_build.f_cpu
needs to match the actual clock speed of the hardware, not what you would like to run it at. And you only have two options with your board, 8 or 16 MHz. At least when using the Arduino framework - which is what is checking the two values and aborting compilation if something else is found.
Having said that, the whole of the USB code is gateposted by a check:
#if defined(USBCON)
#endif /* if defined(USBCON) */
Try adding this to your code:
#if defined(USBCON)
#undef USBCON
That might work, provided nothing in the Arduino framework is turning it back on, however, looking around Goole/DuckDuckGo, it seems that this might require an edit of the main.cpp
file and will result in around 3 KB less code in the compiler output but the autoreset option when uploading new code, might not work and the board may need manual resetting to upload.
I’m not hopeful that you’ll get a fix here. Sorry!
Cheers,
Norm.
