Hello
I’m trying to use de dcsbios on PlatformIO, the library was add an when tryied to compile the error "cannot open source file “Servo.h” (dependency of “DcsBios.h”) " was reported back.
The library used was
some advice on how to fix this issue?
Hello
Since the library using #ifdef / #ifndef blocks to mask out the inclusion of certain libraries, you must use library dependency finder mode that evaluates these macros. By default, it’s not.
#ifndef DCSBIOS_DISABLE_SERVO
#include "internal/Servos.h"
lib_ldf_mode = chain+
in platformio.ini.
https://docs.platformio.org/en/latest/librarymanager/ldf.html#ldf-mode
