HEllo,
I try use simple programe, and i accept this messege on terminal windows. what can I do?
> Executing task in folder terminal: C:\Users\User\.platformio\penv\Scripts\platformio.exe device monitor <
--- Available filters and text transformations: colorize, debug, default, direct, hexlify, log2file, nocontrol,
printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Available ports:
--- Enter port index or full name:
the main.cpp is:
Serial.begin(9600);
Serial.println("hello");
delay(2000);
So, no new USB device for USB-Serial will show up. The core not is not capable of doing that. You would have to connect an external USB-Serial adapter (e.g. an FTDI or ch340 or cp2102 based) to the AIN0 pin, which is PD6, along with GND, to read the serial output.
