Serial.PrintIn() runs ok with Arduino IDE, but not prints to monitor console with PlatformIO
Thank You Sir. But, after disabling the CDConBoot, I still can not see the hello world. Could anyone help me to dig a little deeper on this issue?
When I uses below platformio.ini and USB2Serial Chip:
[env:adafruit_feather_esp32s3]
board = adafruit_feather_esp32s3
; change microcontroller
board_build.mcu = esp32s3
upload_speed = 921600
board_build.f_flash = 80000000L
board_build.f_cpu = 240000000L
board_build.flash_mode = qio
board_build.partitions = default_16MB.csv
   -DARDUINO_USB_CDC_ON_BOOT=0
monitor_port = /dev/cu.usbmodem14*
I got compile warning:
Processing adafruit_feather_esp32s3 (platform: espressif32; board: adafruit_feather_esp32s3; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/adafruit_feather_esp32s3.html
PLATFORM: Espressif 32 (6.3.2) > Adafruit Feather ESP32-S3 2MB PSRAM
HARDWARE: ESP32S3 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olim
ex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 @ 3.20009.0 (2.0.9)
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Found 33 compatible libraries
No dependencies
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduinoVariant\variant.cpp.o
<command-line>: warning: "ARDUINO_USB_CDC_ON_BOOT" redefined
<command-line>: note: this is the location of the previous definition
Compiling .pio\build\adafruit_feather_esp32s3\src\main.cpp.o
Building .pio\build\adafruit_feather_esp32s3\bootloader.bin
Generating partitions .pio\build\adafruit_feather_esp32s3\partitions.bin
esptool.py v4.5.1
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Print.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\USB.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\WString.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\base64.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-i2c-slave.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-rgb-led.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\main.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\adafruit_feather_esp32s3\libFrameworkArduino.a
Linking .pio\build\adafruit_feather_esp32s3\firmware.elf
Retrieving maximum program size .pio\build\adafruit_feather_esp32s3\firmware.elf
Checking size .pio\build\adafruit_feather_esp32s3\firmware.elf
RAM:   [=         ]   6.0% (used 19756 bytes from 327680 bytes)
Flash: [          ]   4.0% (used 263621 bytes from 6553600 bytes)
Building .pio\build\adafruit_feather_esp32s3\firmware.bin
esptool.py v4.5.1
Merged 2 ELF sections
================================================================== [SUCCESS] Took 16.86 seconds ==================================================================
Monitor gave this message:
--- Available ports:
---  1: COM8                 'Standard Serial over Bluetooth link (COM8)'
---  2: COM9                 'Standard Serial over Bluetooth link (COM9)'
---  3: COM21                'Silicon Labs CP210x USB to UART Bridge (COM21)'
---  4: COM22                'USB Serial Device (COM22)'
--- Enter port index or full name: 3
--- Terminal on COM21 | 115200 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter,
 time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x28 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbe4
load:0x403cc700,len:0x2a38
entry 0x403c98d4
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x28 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
I also tried to connect with a USB cable directly to the USB connector. But, still I can not see the hello world. The monitor gave me these message.
--- Enter port index or full name: 4
--- Terminal on COM22 | 115200 8-N-1
 time
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
I also tried:
  • I enable the CDConBoot by setting (-DARDUINO_USB_CDC_ON_BOOT=1). The resulting Monitor messages are the same as above and the compile error was gone.
  • I added the following two lines to platformio.ini based on this post. There is no error. But, Monitor messages are the same as above.
monitor_rts = 0
monitor_dtr = 0
