Serial.PrintIn() runs ok with Arduino IDE, but not prints to monitor console with PlatformIO
Dear Expert,
did you ever encounter this issue? My simple hello world code works with Arduino IDE but can not generate “Hello World” with VScode PlatformIO.
#include "Arduino.h"
#include <stdio.h>
    Serial.println("Hello World?!\n");
    Serial.flush();
    delay(500);
This is my Arduino Setting:
This is my Arduino IDE Serial Monitor reads:
14:21:38.357 -> ESP-ROM:esp32s3-20210327
14:21:38.357 -> Build:Mar 27 2021
14:21:38.357 -> rst:0x1 (POWERON),boot:0x29 (SPI_FAST_FLASH_BOOT)
14:21:38.357 -> SPIWP:0xee
14:21:38.357 -> mode:DIO, clock div:1
14:21:38.357 -> load:0x3fce3808,len:0x44c
14:21:38.357 -> load:0x403c9700,len:0xbe4
14:21:38.357 -> load:0x403cc700,len:0x2a38
14:21:38.357 -> entry 0x403c98d4
14:21:38.421 -> Hello World?!
14:21:38.421 ->
14:21:38.911 -> Hello World?!
14:21:38.911 ->
14:21:39.399 -> Hello World?!
14:21:39.399 ->
14:21:39.919 -> Hello World?!
If I upload the code using Arduino IDE first and then use PlatformIO to monitor, VScode PlatformIO Monitor can see “Hello World”. Everything works ok. But, The PlatformIO Monitor does not work when I upload the same code with the VScode PlatformIO.
This is my the platformio.ini code and the main.cpp contains the same hello world code as the Arduino sketch:
[env:adafruit_feather_esp32s3]
board = adafruit_feather_esp32s3
; change microcontroller
board_build.mcu = esp32s3
upload_speed = 921600
board_build.f_flash = 80000000L
board_build.flash_mode = qio
monitor_port = COM21
board_build.partitions = default_16MB.csv
This is what platformIO monitor shows once after I uploaded the code to my ESP32-S3-WROOM-1-N16R2 board with PlatformIO->Upload and Monitor.
Processing adafruit_feather_esp32s3 (platform: espressif32; board: adafruit_feather_esp32s3; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/adafruit_feather_esp32s3.html
PLATFORM: Espressif 32 (6.3.2) > Adafruit Feather ESP32-S3 2MB PSRAM
HARDWARE: ESP32S3 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-oc
d-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 @ 3.20009.0 (2.0.9)
 - tool-mkfatfs @ 2.0.1
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Found 33 compatible libraries
Retrieving maximum program size .pio\build\adafruit_feather_esp32s3\firmware.elf
Checking size .pio\build\adafruit_feather_esp32s3\firmware.elf
RAM:   [=         ]   9.6% (used 31544 bytes from 327680 bytes)
Flash: [          ]   4.2% (used 276857 bytes from 6553600 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olim
Looking for upload port...
Auto-detected: COM21
Forcing reset using 1200bps open/close on port COM21
Waiting for the new upload port...
Uploading .pio\build\adafruit_feather_esp32s3\firmware.bin
esptool.py v4.5.1
Serial port COM21
Connecting....
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 34:85:18:b4:2f:04
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00010000 to 0x00053fff...
Compressed 15040 bytes to 10331...
Writing at 0x00000000... (100 %)
Wrote 15040 bytes (10331 compressed) at 0x00000000 in 0.3 seconds (effective 359.3 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.0 seconds (effective 513.3 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 747.0 kbit/s)...
Compressed 277216 bytes to 158089...
Writing at 0x00010000... (10 %)
Writing at 0x0001c4c9... (20 %)
Writing at 0x0002466d... (30 %)
Writing at 0x00029c42... (40 %)
Writing at 0x0002efbc... (50 %)
Writing at 0x00034239... (60 %)
Writing at 0x0003a53c... (70 %)
Writing at 0x00044b77... (80 %)
Writing at 0x0004a36f... (90 %)
Writing at 0x0004fd61... (100 %)
Wrote 277216 bytes (158089 compressed) at 0x00010000 in 2.6 seconds (effective 845.9 kbit/s)...
Leaving...
Hard resetting via RTS pin...
--- Terminal on COM21 | 115200 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_
on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
Build:Mar 27 2021
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x29 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
The PlatformIO monitor does not see “Hello World?!” but some strange messages:
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Your board definition adafruit_feather_esp32s3 has
  -DARDUINO_USB_CDC_ON_BOOT=1
which would correspond to the Arduino Setting
  USB CDC On Boot: "Enabled"
which is disabled in your Arduino IDE settings (see your screenshot)
With this setting enabled, all Serial.print statements are routed to the native USB port on the ESP32. If you want to use the RX/TX pin and/or the USB2Serial Chip you have either to disable this setting by adding
build_flags=
  -DARDUINO_USB_CDC_ON_BOOT=0
to your platformio.ini or use Serial0 in your sketch.
Thank You Sir. But, after disabling the CDConBoot, I still can not see the hello world. Could anyone help me to dig a little deeper on this issue?
When I uses below platformio.ini and USB2Serial Chip:
monitor_port = /dev/cu.usbmodem14*
I got compile warning:
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olim
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduinoVariant\variant.cpp.o
<command-line>: warning: "ARDUINO_USB_CDC_ON_BOOT" redefined
<command-line>: note: this is the location of the previous definition
Compiling .pio\build\adafruit_feather_esp32s3\src\main.cpp.o
Building .pio\build\adafruit_feather_esp32s3\bootloader.bin
Generating partitions .pio\build\adafruit_feather_esp32s3\partitions.bin
esptool.py v4.5.1
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Print.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\USB.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\WString.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\base64.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-i2c-slave.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-rgb-led.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\main.cpp.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\adafruit_feather_esp32s3\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\adafruit_feather_esp32s3\libFrameworkArduino.a
Linking .pio\build\adafruit_feather_esp32s3\firmware.elf
RAM:   [=         ]   6.0% (used 19756 bytes from 327680 bytes)
Flash: [          ]   4.0% (used 263621 bytes from 6553600 bytes)
Building .pio\build\adafruit_feather_esp32s3\firmware.bin
esptool.py v4.5.1
Merged 2 ELF sections
================================================================== [SUCCESS] Took 16.86 seconds ==================================================================
Monitor gave this message:
--- Available ports:
---  1: COM8                 'Standard Serial over Bluetooth link (COM8)'
---  2: COM9                 'Standard Serial over Bluetooth link (COM9)'
---  3: COM21                'Silicon Labs CP210x USB to UART Bridge (COM21)'
---  4: COM22                'USB Serial Device (COM22)'
--- Enter port index or full name: 3
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter,
 time
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x28 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x28 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
I also tried to connect with a USB cable directly to the USB connector. But, still I can not see the hello world. The monitor gave me these message.
--- Enter port index or full name: 4
--- Terminal on COM22 | 115200 8-N-1
 time
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
Build:Mar 27 2021
Saved PC:0x403cd9f6
SPIWP:0xee
entry 0x403c98d4
I also tried:
  • I enable the CDConBoot by setting (-DARDUINO_USB_CDC_ON_BOOT=1). The resulting Monitor messages are the same as above and the compile error was gone.
  • I added the following two lines to platformio.ini based on this post. There is no error. But, Monitor messages are the same as above.
monitor_rts = 0
monitor_dtr = 0
However, Once I changed the platformio.ini to another board and a different csv file, the issue was magically solved. Could any expert know what default board setting and csv configurations cause this difference?
This is my new platformio.ini. I only changed the board from adafruit_feather_esp32s3 to esp32-s3-devkitc-1 and the CSV file from default_16MB.csv to my.csv:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
board_build.partitions = my.csv
The Monitor now has the “Hello Word?!” reading:
 time
Build:Mar 27 2021
SPIWP:0xee
entry 0x403c98d4
E (78) esp_core_dump_flash: No core dump partition found!
Hello World?!
Hello World?!
Hello World?!
You have used different board settings in platformio.ini (first adafruit_feather_esp32s3 and now esp32-s3-devkitc-1).
In addition, you set some extra parameters that should not be necessary for a “standard board”.
All these settings must match your board.
The settings you have made differ from your Arduino IDE settings (e.g. the 16 MB partition, whereas you have only set 4MB in the Arduino IDE).
Please try a minimal settings:
Then only change settings what really needs to be changed.
Which board do you use exactly?
What specification does it have (size of flash, size of PSRAM)?
By the way: You can choose the COM port to be used in the bottom statusbar:
Yes, Sir. I tried your code and it works perfect.
And, this is the Monitor reading.
 time
Build:Mar 27 2021
SPIWP:0xee
entry 0x403c98d4
Hello World?!
Hello World?!
Hello World?!
Hello World?!
Hello World?!
Hello World?!
Hello World?!
My board is ESP32-S3-WROOM-1-N16R2.
16MB Flash, 384kB ROM, 2MB SRAM based on Digikey
your solution @sivar2311 works well but…
I am using ESP32 for sensors that wake up from sleep, measure things, send over ESPnow and go to sleep. Entire process takes around 120-350ms depending what they measure.
And I recently tried S3 with that project and there is a small issue: because it is NOT hardware serial but built in USB inside S3, the time of 350ms is not enough for ESP32-S3 to get connected to Platformio, so there is no print on screen.
Everything else works.
When I use the same S3 with the sketch, where it does not go to sleep so fast, all is visible again.
Any solution for that?
thank you
Hi @zyghom
When the ESP32S3 goes into deep sleep, the built-in USB controller is shut down. This causes the computer to lose the “virtual” COM port.
When the ESP wakes up again, it takes some time for the USB connection to be established and the “virtual” COM port on your computer to be set up again.
In your serial terminal program, you would have to wait exactly the time for the “virtual” COM port to become available and only then open the connection (before it is lost again as the ESP goes into deep sleep).
I think for your application the built-in USB is not a solution. You need to use UART with an external USB to serial chip that keeps the serial connection to the computer while the ESP32 is in deep sleep.
@sivar2311 - you confirmed what I was thinking
thank you
So, if I may ask you: how do I define Serial on S3?
And to which GPIO should I connect?
Something like this? (espressif says: Serial on any GPIO)
#define RX_PIN 1
#define TX_PIN 2
SoftwareSerial mySerial(RX_PIN, TX_PIN);
mySerial.begin(115200);
mySerial.println("hello world");
As I wrote in my first post in this thread, you can either disable USB CDC and use Serial or use Serial0 (if USB CDC is enabled). You don’t have to use SoftwareSerial.
Since you don’t make use of the USB capabilities I suggest to disable USB CDC and simply use Serial.
OK, maybe I am making something up, but I am now at such thing and it works - should I do it different way? I need to define GPIOs somewhere, right?
HardwareSerial mySerial(0);
mySerial.begin(115200, SERIAL_8N1, RX_PIN, TX_PIN);
No, you don’t need to define GPIO’s or create an extra Serial object.
If you have USB CDC enabled, just use Serial0.
In this case Serial0 is connected to the RX and TX gpio’s.
  Serial0.println("Hello World");
If USB CDC is disabled just use Serial.
In this case Serial is connected to the RX and TX gpio’s.
  Serial.println("Hello World");
@sivar2311
See, this is what I just realised because I was confused about GPIOs and in https://github.com/espressif/arduino-esp32/blob/master/cores/esp32/HardwareSerial.cpp I found:
#ifndef RX1
#if CONFIG_IDF_TARGET_ESP32
#define RX1 9
#elif CONFIG_IDF_TARGET_ESP32S2
#define RX1 18
#elif CONFIG_IDF_TARGET_ESP32C3
#define RX1 18
#elif CONFIG_IDF_TARGET_ESP32S3
#define RX1 15
and similar for TX1
So, if I don’t use GPIO definition, by default RX=15 and TX=16 on S3 (unless I want to change them)
so now, because I have common sketch for all my devices (ESP32, S2, S3, C3), for the boards with S3 I added in config.h:
#define USE_UART
#define RX_PIN 1
#define TX_PIN 2
and further in the setup():
#ifdef USE_UART
  #else
that OK now? I mean: it works
If you are developing an application for different ESP modules, this looks like a viable solution.
