Serial print problems again!
My class is using PlatformIO IDE to develop their own code for SPI read and write. We are doing a lab where we read data from the ADXL345 accelerometer (all 3 axis).
To see the values of the x,y and z axis - we are using the Serial.print(); statement. There seems to be an issue with it working sometimes and not working. I have changed the serial.flush command location but there is still an intermittent issue.
Moderator edit: added code formatting tags and removed blank lines
Here is the platformio file contents:
[env:megaatmega2560]
board = megaatmega2560
Here is the code:
main():
#include <avr/io.h>
#include "spi.h"
unsigned char POWER_CTL = 0x2D;   // Power Control Register
unsigned char DATA_FORMAT = 0x31; // Data Format Register
int main(){
  // Set baud rate for serial transmission, flush before printing anything
  Serial.begin(9600);
  //Serial.flush();
  // initialize SPI
  //Serial.println("initSPI()");
  initSPI();
  spi_write(POWER_CTL, 0x08);   // set to measure mode
  spi_write(DATA_FORMAT, 0x00); // configure 4-wire mode by clearing the SPI bit
  while(1){
    // Read current XYZ position from ADXL345
    Serial.println("readAccel()");
    Serial.flush();
    readAccel();
    printCoords();
    // Delay for 1000 ms
  _delay_ms(1000);
  return 0;
spi.ccp
#include "spi.h"
#include <avr/io.h>
#define wait_for_completion while(!(SPSR & (1<<SPIF)));
unsigned char DATAX0_REG = 0x32;      // X-Axis Data 0 Register
unsigned char DATAX1_REG = 0x33;      // X-Axis Data 1 Register
unsigned char DATAY0_REG = 0x34;      // Y-Axis Data 0 Register
unsigned char DATAY1_REG = 0x35;      // Y-Axis Data 1 Register
unsigned char DATAZ0_REG = 0x36;      // Z-Axis Data 0 Register
unsigned char DATAZ1_REG = 0x37;      // Z-Axis Data 1 Register
unsigned char dataX0, dataX1, dataY0, dataY1, dataZ0, dataZ1;
int dataX, dataY, dataZ;
void initSPI(){
  // set the SS, MOSI, and SCLK pin as output
  DDRB |= (1 << DDB0) | (1 << DDB1) | (1 << DDB2);
  // set the MISO pin as input
  DDRB &= ~(1 << DDB3);
  // set SS high at first
  PORTB |= (1 << PORTB0);
  // enable the interrupt, SPI, master mode, CPOL, CPHA, default clock, and fosc/128
  //ADXL345 CPOL = 1, CPHA = 1
  SPCR |= (1 << SPIE) | (1 << SPE) | (1 << MSTR) | (1 << CPOL)| (1 << CPHA)| (1 << SPR1) | (1 << SPR0);
  // Initialize data read variables
  dataX0 = 0;
  dataX1 = 0;
  dataX = 0;
  dataY0 = 0;
  dataY1 = 0;
  dataY = 0;
  dataZ0 = 0;
  dataZ1 = 0;
  dataZ = 0;
  /*Serial.print("X: ");
  Serial.println(dataX);
  Serial.print("Y: ");
  Serial.println(dataY);
  Serial.print("Z: ");
  Serial.println(dataZ);
  Serial.println();*/
write to a register of an SPI device
regAddress = register address of the SPI device
value = value to be written to the specified register of the SPI device
void spi_write(unsigned char regAddress, unsigned char value){
  // set SS low to begin SPI frame
  PORTB &= ~(1 << PORTB0);
  SPDR = regAddress;
  wait_for_completion;
  SPDR = value;
  // set SS high to end SPI frame
  //_delay_ms(1000);
unsigned char spi_read (unsigned char regAddress)
  // 0x80 = read mask; 0x00 = dummy value to be sent
  spi_write (0x80 | regAddress, 0x00);
  return SPDR;
void readAccel(){
  // Read X0 & X1 Data
  dataX0 = spi_read(DATAX0_REG);
  dataX1 = spi_read(DATAX1_REG);
  // Combine X0 and X1
  dataX = (dataX1 << 8) | dataX0;
  // Read Y0 & Y1 Data
  dataY0 = spi_read(DATAY0_REG);
  dataY1 = spi_read(DATAY1_REG);
  // Combine Y0 and Y1
  dataY = (dataY1 << 8) | dataY0;
  // Read X0 & Z1 Data
  dataZ0 = spi_read(DATAZ0_REG);
  dataZ1 = spi_read(DATAZ1_REG);
  dataZ = (dataZ1 << 8) | dataZ0;
void printCoords(){
  //Serial.flush();
  Serial.println();
Any ideas why sometimes the serial print results are:
readAccel()
X: 0
Y: 0
Z: 0
readAccel()
X: 0
Y: 0
Z: 0
and then other times after maybe pulling a chip select wire and reattaching it I get values:
readAccel()
X: -22
Y: 0
Z: 234
readAccel()
X: -22
Y: 0
Z: 235
So I take it at the moment the output
readAccel()
X: 0
Y: 0
Z: 0
output is coming from loop and printCoords()?
main.cpp:loop() >> readAccel()
spi.cpp:printCoords() >> X: 0
spi.cpp:printCoords() >> Y: 0
spi.cpp:printCoords() >> Z: 0
I don’t see a Serial.flush doing anything there - it’s not like you’re shutting down the MCU and need to ensure that all serial output is sent before the peripheral is turned off, etc. Plus, it’s not going to change it’s behaviour if you make a change to the circuit… that is suggestive of either an initialisation issue in the program, or a problem with the wiring/connections. When you said after pulling a chip select you’re getting different values… is the code actually working (i.e. updating as you move the accelerometer) or are the numbers different but still static/unchanging?
Have you checked that the spi_read functions are getting back valid data? i.e… maybe add something like the following to it and see if the right data is actually getting to the Arduino in the first place. It could be something like the SPI initialisation code needs tweaking - SPI speed, etc, or even just the order of the DATA_FORMAT and POWER_CTL commands… i.e. you’ve configured SPI mode AFTER enabling measure mode… does it even understand instruction yet? Just something to double check.
Serial.print("spi_read(): regAddress =  ");
Serial.print(regAddress);
Serial.print(", returned data = ");
Serial.println(SPDR);
One silly issue question… you are using the Arduino Mega SPI pins (50-53) rather than standard Uno ones (10-13)? Not that I would have ever done that… :open_mouth:
I’ve checked the wiring issues. I’ve attached the connection schematic. I’m going the slowest possible clock (125 kHz) using the fosc/128. I’ll switch around the data_format and Power_CTL - that’s a good point. I’m using pins 50-53 yes. It must be an initialization issue then.
When I get numbers printing out as shown: yes when I tilt the device the axis numbers change accordingly. I’ll check the SPI read function again. Thanks so much for your ideas!
Oh… it’s possible those boards ONLY support I2C, as they would have the pullup resistors on SCL/SCK & SDA/MOSI, which shouldn’t be there for SPI (more on that here). :-/
It looks like R3 is one of them as it goes to SDA, not sure which one is pulling up SCL… maybe R2? If you have one you can sacrifice to test, I’d be removing those resistors (of they are indeed the correct ones) to see if it ‘suddenly works’ with SPI. Otherwise, it’s I2C only, and you’d be after boards like the sparkfun ones with are basically nothing more than the chip and a couple of capacitors, which is why they were I2C and SPI ready (since you added the pullup resistors yourself if you used I2C, and didn’t need anything if using SPI).
