platformio-ini
[env:swervolf_nexys]
platform = chipsalliance
board = swervolf_nexys
framework = wd-riscv-sdk
board_build.bitstream_file = /home/konrad/Desktop/RVfpga_Prog_4_uart/rvfpga.bit
this is my address settings ↓
code:
#if defined(D_NEXYS_A7)
#include <bsp_printf.h>
#include <bsp_mem_map.h>
#include <bsp_version.h>
#else
PRE_COMPILED_MSG("no platform was defined")
#include <psp_api.h>
#define READ_IO(addr) (volatile unsigned int *)(addr)
#define WRITE_IO(addr) (volatile unsigned int *)( addr)
#define inline_assembly() asm("ori $0, $0, 0x1234")
#define IO_SWs 0x80100008
#define IO_LEDR 0x80100000
#define UART_BASE 0x80110000
#define rbr 0*4
#define ier 1*4
#define fcr 2*4
#define lcr 3*4
#define mcr 4*4
#define lsr 5*4
#define msr 6*4
#define scr 7*4
#define thr rbr
#define iir fcr
#define dll rbr
#define dlm ier
void delay()
for(unsigned int i=0;i<100000;++i);
int main()
//printfNexys("hello world\n");
*WRITE_IO(UART_BASE + lcr) = 0x00000080; // LCR[7] is 1
delay();
*WRITE_IO(UART_BASE + dll) = 27; // DLL msb. 115200 at 50MHz. Formula is Clk/16/baudrate. From axi_uart manual.
delay();
*WRITE_IO(UART_BASE + dlm) = 0x00000000; // DLL lsb.
delay();
*WRITE_IO(UART_BASE + lcr) = 0x00000003; // LCR register. 8n1 parity disabled
delay();
*WRITE_IO(UART_BASE + ier) = 0x00000000; // IER register. disable interrupts
delay();
while (1)
delay();
*WRITE_IO(UART_BASE + thr) = 0x00000048;
delay();
*WRITE_IO(UART_BASE + thr) = 0x00000065;
delay();
*WRITE_IO(UART_BASE + thr) = 0x0000006C;
delay();
delay();
*WRITE_IO(UART_BASE + thr) = 0x0000006F;
delay();
*WRITE_IO(UART_BASE + thr) = 0x00000020;
delay();
*WRITE_IO(UART_BASE + thr) = 0x00000077;
delay();
delay();
*WRITE_IO(UART_BASE + thr) = 0x00000072;
delay();
delay();
*WRITE_IO(UART_BASE + thr) = 0x00000064;
delay();
*WRITE_IO(UART_BASE + thr) = 0x0000000A;
delay();
return 0;
