When flashing the ESP32-S3 using Arduino IDE , the Serial Monitor works as expected .
However, when flashing the exact same code using PlatformIO , no serial output appears afterward.
My platformio.ini
[env:lolin_s3]
board = lolin_s3
monitor_port = /dev/ttyUSB0
build_flags = -D PIO_FRAMEWORK_ARDUINO_USB_CDC_ON_BOOT=1
Arduino IDE settings:
board: LOLIN S3
port: tty/USB0
the code is:
void setup()
delay(1000);
Serial.println("Hello from LOLIN S3!");
void loop()
Serial.println("Still alive...");
delay(1000);
I’d appreciate any help or suggestions on what might be missing in my PlatformIO setup. Thanks!
