Hi everyone !
Here’s the project : I’m trying to drive a PCF8563 with I2C 1 on pins 14 & 15
Working:
- I2C Communication, signals are OK on scope
- Firmware compilation & upload
Not working:
- Serial Monitor, as in the title (see screenshot below)
main.cpp
#include "RTC.h"
RTC rtc; //this is a custom class
Serial.begin(9600);
rtc.begin(5000);
rtc.setCLKOUTFreq(RTC::CLKOUT_FREQ::F1024);
delay(1000);
int seconds = rtc.getSeconds();
Serial.println("Second : " + seconds);
platformio.ini
[env:pico]
platform = raspberrypi
board = pico
build_flags = -std=gnu++17
build_unflags = -std=gnu++11
monitor_speed = 9600
RTC.cpp
#include "RTC.h"
#include <Wire.h>
#define PCF8563address 0x51
#define WIRE1_SDA 14
#define WIRE1_SCL 15
MbedI2C Wire1(WIRE1_SDA, WIRE1_SCL);
const byte CLKOUT_REGISTER_ADDRESS = 0x0D;
const byte SECONDS_REGISTER = 0x02;
const uint32_t SCL_FREQ = 400000;
RTC::RTC(){}
RTC::~RTC(){
Wire1.end();
void RTC::begin(unsigned long timeoutMs){
Wire1.begin();
Wire1.setTimeout(timeoutMs);
Wire1.setClock(SCL_FREQ);
uint8_t RTC::setCLKOUTFreq(RTC::CLKOUT_FREQ freq){
Wire1.beginTransmission(PCF8563address);
int bytesWritten = Wire1.write(CLKOUT_REGISTER_ADDRESS);
bytesWritten += Wire1.write(0x80 + freq);
Serial.println(bytesWritten + " written bytes");
return Wire1.endTransmission();
uint8_t RTC::getSeconds(){
Wire1.write(SECONDS_REGISTER);
Wire1.requestFrom(PCF8563address, 1);
int secBcd = Wire1.read() & 0x7F;
return bcdToDec(secBcd);
uint8_t RTC::bcdToDec(uint8_t bcd){
uint8_t u = bcd & 0x0F;
uint8_t d = (bcd & 0xF0) * 10;
return u + d;
uint8_t RTC::decToBcd(uint8_t dec){
uint8_t u = dec % 10;
uint8_t d = (dec - u) / 10;
return u | (d << 4);
Tried these solutions but it changed NOTHING ![]()
- In Serial Monitor outputs unreadable characters topic
- Match baud on .ini and
Serial.begin(also tried (baud in .ini)/4 inSerial.beginand (baud inSerial.begin)/4 in .ini) - Put
monitor_flags = --raw(but doens’t exists in my case) - Put
monitor_filters = direct - Set explicitly the flash speed
- Change
SerialtoSerial1(andSerialUSB) - Moving the delay to between I2C operation and
Serial.println - Added a second delay like this :
delay(500);
delay(500);
All of that just for showing seconds to test reading values from the PCF8563 chip ![]()
I confirm that I endTransmission with stop bit after each writing operation
Any other ideas to solve this once and for all? (literally for all, this time)
PS: each of these solutions change garbage output a little bit, but it’s still garbage
PS 2: this problem and the SUPER SLOW compilation time (20 seconds to 2 minutes) are getting me out of patience, so I apologize for any misbehavior I may have
