I’m using PlatformIO on VS Code (Windows) to upload and test code on a ESP32-CAM module.
To upload and to use the serial monitor I’m using an USB-to-TTL converter.
Compiling and uploading works perfect.
However the serial monitor crashes after startup/restart of the ESP32.
Here is the output of the serial monitor:
> Executing task in folder ESP32-Cam-Webserver: C:\Users\claus\.platformio\penv\Scripts\pio.exe device monitor <
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at http://bit.ly/pio-monitor-filters
--- Miniterm on COM3 115200,8,N,1 ---
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5828
entry 0x400806ac
Exception in thread rx:
File "C:\Users\claus\.platformio\python3\lib\threading.py", line 926, in _bootstrap_inner
self.run()
File "C:\Users\claus\.platformio\python3\lib\threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "c:\users\claus\.platformio\penv\lib\site-packages\serial\tools\miniterm.py", line 445, in reader
data = self.serial.read(self.serial.in_waiting or 1)
File "c:\users\claus\.platformio\penv\lib\site-packages\serial\serialwin32.py", line 257, in in_waiting
raise SerialException("ClearCommError failed ({!r})".format(ctypes.WinError()))
serial.serialutil.SerialException: ClearCommError failed (PermissionError(13, 'Zugriff verweigert', None, 5))
