Serial Monitor always print 'NUL' in VS Code
  1. On reset, the ESP8266 will print bootloader messages at 74880 baud. Since you have set the monitor to 115200 baud, the USB-UART adapter cannot correctly the UART TX signal and prints the wrong data. What is being output at minotor_speed = 74880? I suspect your ESP just can’t boot.
  2. I see that you’re using a Mac by that /dev/cu.usbserial* device name. Serial drivers for like CH340 chips are known to be very buggy / needing the exact right kernel driver. See Troubleshooting CH340G issues on macOS. If no sensible output is shown on any baud rate, a driver issue may be fault.
