Hello community,
I have installed Sensirion I2C SGP41 lib in a new project, but still I don’t manage to read any sensor values. The SGP41 is connected to ESP32-S3 with SDA pin 37 and SCL pin 38. I can read the serial number but the sensor data values are blank.
Does anyone have any idea what is going wrong here?
Thanks in advance
Alex
Code:
#include <SensirionI2CSgp41.h>
#include <Wire.h>
SensirionI2CSgp41 sgp41;
// time in seconds needed for NOx conditioning
uint16_t conditioning_s = 10;
Serial.begin(115200); while (!Serial) { delay(100); } Wire.setPins(37,38); Wire.begin(); uint16_t error; char errorMessage[256]; sgp41.begin(Wire); uint16_t serialNumber[3]; uint8_t serialNumberSize = 3; error = sgp41.getSerialNumber(serialNumber, serialNumberSize); if (error) { Serial.print("Error trying to execute getSerialNumber(): "); errorToString(error, errorMessage, 256); Serial.println(errorMessage); } else { Serial.print("SerialNumber:"); Serial.print("0x"); for (size_t i = 0; i < serialNumberSize; i++) { uint16_t value = serialNumber[i]; Serial.print(value < 4096 ? "0" : ""); Serial.print(value < 256 ? "0" : ""); Serial.print(value < 16 ? "0" : ""); Serial.print(value, HEX); } Serial.println(); } uint16_t testResult; error = sgp41.executeSelfTest(testResult); if (error) { Serial.print("Error trying to execute executeSelfTest(): "); errorToString(error, errorMessage, 256); Serial.println(errorMessage); } else if (testResult != 0xD400) { Serial.print("executeSelfTest failed with error: "); Serial.println(testResult); }}
uint16_t error; char errorMessage[256]; uint16_t defaultRh = 0x8000; uint16_t defaultT = 0x6666; uint16_t srawVoc = 0; uint16_t srawNox = 0; delay(1000); if (conditioning_s > 0) { // During NOx conditioning (10s) SRAW NOx will remain 0 error = sgp41.executeConditioning(defaultRh, defaultT, srawVoc); conditioning_s--; } else { // Read Measurement error = sgp41.measureRawSignals(defaultRh, defaultT, srawVoc, srawNox); } if (error) { Serial.print("Error trying to execute measureRawSignals(): "); errorToString(error, errorMessage, 256); Serial.println(errorMessage); } else { Serial.print("SRAW_VOC:"); Serial.print(srawVoc); Serial.print("\t"); Serial.print("SRAW_NOx:"); Serial.println(srawNox); }}
Monitor output:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x39c
load:0x403b6000,len:0x9a4
load:0x403ba000,len:0x2868
entry 0x403b61c0
SerialNumber:0x000001936FB5
Error trying to execute executeSelfTest(): Not enough data received
Error trying to execute measureRawSignals(): Not enough data received
