SendOnlySoftwareSerial on ATtiny402
I was keen to know if you can use Nick Gammon’s SendOnlySoftwareSerial as a debug aid on an ATtiny402 as this device only has a few pins.
Well it turns out you can - I had to specify 0 as the TXD pin and this made serial data appear on the default pin PA6 (If you try to specify this as using pin 6 - you get the error "Digital pin is constant, but not a valid pin"
Here’s a working ‘Blinky’ type program and PlatformIO.ini.
// ATtiny402 as test device
// Example code using SendOnlySoftwareSerial by Nick Gammon - uses less flash than Serial.print()
// Warning - if you're using interrupts - beware!
// <https://github.com/nickgammon/SendOnlySoftwareSerial>
#include <SendOnlySoftwareSerial.h>		// saves a pin for output debug
/*  pin information
			    ATtiny402
		        ----u---
  	    	VDD|		 |GND
		TXD PA6|		 |PA3
   		RXD PA7|		 |PA0 UDIP
	  		PA1|		 |PA2
#define BAUD 38400						// serial comms baud rate
SendOnlySoftwareSerial mySerial (0);	// set up the serial output stream to PA6 - I guess 0 means default ??
void system_init(void);           		// placeholder for compiler - but there's not much initialisation to do for this example
    system_init();
	mySerial.begin(BAUD);
	mySerial.println(F("\r\n\r\nStarting"));
  mySerial.print(F("."));
  delay(500);
void mcu_init(void)							/* MCU initialization */
	/* On AVR devices all peripherals are enable from power on reset, this
	 * disables all peripherals to save power. Driver shall enable
	 * peripheral if used */
	/* Set all pins to low power mode */
	for (uint8_t i = 0; i < 8; i++) {
		*((uint8_t *)&PORTA + 0x10 + i) |= 1 << PORT_PULLUPEN_bp;
void system_init(){							/* system initialization */
	mcu_init();
[env:ATtiny402]
platform = atmelmegaavr
board = ATtiny402
board_build.f_cpu = 20000000L
upload_speed = 115200
upload_port = COM7
upload_flags =
    --tool
    uart
    --device
    attiny402
    --uart
    $UPLOAD_PORT
    --clk
    $UPLOAD_SPEED
upload_command = pymcuprog write --erase $UPLOAD_FLAGS --filename $SOURCE
I had to download the library and insert the SendOnlySoftwareSerial.cpp and SendOnlySoftwareSerial.h in the lib folder as per picture below
The compilation / load output is as below
 *  Executing task in folder ATtiny402_SendOnlySoftware_SerialTest: C:\Users\Peter\.platformio\penv\Scripts\platformio.exe run --target upload
Processing ATtiny402 (platform: atmelmegaavr; board: ATtiny402; framework: arduino)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/ATtiny402.html
PLATFORM: Atmel megaAVR (1.6.0) > ATtiny402
HARDWARE: ATTINY402 20MHz, 256B RAM, 4KB Flash
 - framework-arduino-megaavr-megatinycore @ 2.5.11
 - tool-avrdude-megaavr @ 3.60300.220118 (6.3.0)
 - toolchain-atmelavr @ 3.70300.220127 (7.3.0)
Found 16 compatible libraries
|-- SendOnlySoftwareSerial
Compiling .pio\build\ATtiny402\src\main.cpp.o
Linking .pio\build\ATtiny402\firmware.elf
Checking size .pio\build\ATtiny402\firmware.elf
RAM:   [=         ]  12.1% (used 31 bytes from 256 bytes)
Flash: [===       ]  25.3% (used 1035 bytes from 4096 bytes)
AVAILABLE: jtag2updi
CURRENT: upload_protocol = jtag2updi
Looking for upload port...
Using manually specified: COM7
Uploading .pio\build\ATtiny402\firmware.hex
Connecting to SerialUPDI
Pinging device...
Ping response: 1E9227
Erasing device before writing from hex file...
Writing from hex file...
Writing flash...
Done.
=============================================================================== [SUCCESS] Took 8.62 seconds ===============================================================================
Enjoy…
