I am trying to get semihosting to work on my bluepill. I followed this thread’s guides here step by step but I am getting the following error when running the task “OpenOCD (semihosting output)” and when trying to debug as well.
When debugging, the Consol’s output is:
Processing bluepill_f103c8 (platform: ststm32; board: bluepill_f103c8; framework: cmsis)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/bluepill_f103c8.html
PLATFORM: ST STM32 (12.1.1) > BluePill F103C8
HARDWARE: STM32F103C8T6 72MHz, 20KB RAM, 64KB Flash
DEBUG: Current (custom) External (blackmagic, cmsis-dap, jlink, stlink)
- framework-cmsis 2.50501.200527 (5.5.1)
- framework-cmsis-stm32f1 4.3.1
- tool-ldscripts-ststm32 0.1.0
Warning! Cannot find a linker script for the required board! An auto-generated script will be used to link firmware!
Found 0 compatible libraries
Building in debug mode
Checking size .pio/build/bluepill_f103c8/firmware.elf
RAM: [ ] 1.6% (used 328 bytes from 20480 bytes)
Flash: [= ] 6.6% (used 4320 bytes from 65536 bytes)
========================= [SUCCESS] Took 1.76 seconds =========================
Reading symbols from /Users/engmoh/Embedded/PlatformIO_Projects/STM32_Projects/0-SemiHosting_Configurations/.pio/build/bluepill_f103c8/firmware.elf...
done.
PlatformIO: debug_tool = custom
:3333: Operation timed out.
When running the task, Terminal’s output is:
> Executing task in folder 0-SemiHosting_Configurations: cd ~/.platformio/packages/tool-openocd && bin/openocd -f scripts/interface/stlink.cfg -f target/stm32f1x.cfg <
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-12:31)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : clock speed 1000 kHz
Info : STLINK V2J37S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 1.436903
Error: target voltage may be too low for reliable debugging
Warn : UNEXPECTED idcode: 0x2ba01477
Error: expected 1 of 1: 0x1ba01477
The terminal process "/bin/zsh '-c', 'cd ~/.platformio/packages/tool-openocd && bin/openocd -f scripts/interface/stlink.cfg -f target/stm32f1x.cfg'" terminated with exit code: 1.
My platformio.ini
[env:bluepill_f103c8]
platform = ststm32
board = bluepill_f103c8
framework = cmsis
upload_protocol = stlink
; ============ Enable Arm Semihosting in debugger to show logs =============
extra_scripts = extra_script.py ; Must be located in the main project folder
build_unflags =
--specs=nosys.specs
-lnosys
debug_extra_cmds =
monitor arm semihosting enable
debug_tool = custom
debug_port = :3333
; Enable Chinese clones STM32 MCUs recognition (Fixing "Warn : UNEXPECTED idcode: 0x2ba01477" Error)
upload_flags = -c set CPUTAPID 0 ;This will allow Originals and Clones to debug
my Tasks.json
"version": "2.0.0",
"tasks": [
"type": "shell",
"command": "cd ~/.platformio/packages/tool-openocd && bin/openocd -f scripts/interface/stlink.cfg -f target/stm32f1x.cfg",
"args": [
"problemMatcher": [
"$platformio"
"label": "OpenOCD (semihosting output)"
and my main.c
#include <stm32f1xx.h>
#include <stdio.h>
/* semihosting Initializing */
extern void initialise_monitor_handles(void);
int main(void)
initialise_monitor_handles();
printf("Hello .. Echo .. Echo\n");
I think I should use “-c set CPUTAPID 0” somewhere in the tasks.json probably but I don’t know where! but what about debugging? why It’s not working?
