Does anyone know if there’s support for selecting a given framework when generating a project for an IDE? In my specific case I’d like to generate an eclipse project for the disco_f407vg platform while using the spl framework (rather than the mbed framework, which is used by default).
Ah, thanks! It wasn’t immediately clear that the ‘pio init’ command would respect any existing configuration, so fwiw adding a line to the help command could help others looking for the same solution. Regardless of that, thanks again!
I haven’t really thought this through yet, but as this is the current output
$ platformio init
The current working directory /home/stm32dev will be used for project.
You can specify another project directory via
`platformio init -d %PATH_TO_THE_PROJECT_DIR%` command.
The next files/directories will be created in /home/stm32dev
platformio.ini - Project Configuration File. |-> PLEASE EDIT ME <-|
src - Put your source files here
Do you want to continue? [y/N]: n
then maybe something like
$ platform io init
Assuming an empty directory, the following files/directories will be created in /home/stm32dev
Should platformio.ini already exist its settings will be parsed and any associated
settings (such as IDE project settings) will be updated.
would be clearer? (Additionally, it might be good to update Redirecting... as well to clarify that an existing configuration file will, if detected, regenerate the project based on its settings).
True, and it’s possible that most people won’t exhibit the same misunderstanding, but my assumption was that platformio.ini was only parsed by ‘pio run’ and its variants (which would make some kind of sense as there are many build-related options that can be configured). It all comes down to the desired level of verbosity in the project’s documentation =)
Would really help to have a simple description in the usage for platformio cmd indicating that specifying –help after a command will display usage for that particular command.
