Seeeduino Lotus Cortex M0+: correct platformio.ini settings?
I am trying to set platformio up for the Seeeduino Lotus Cortex M0+ dev board. It has a SAMD21 MCU, and I can not find a fitting board setting in the PIO “new project” dialog.
What worked to upload, but may be wrong is using “board = seeed_xiao” in platformio.ini.
[env:seeed_xiao] ; I know this is not correct
platform = atmelsam
board = seeed_xiao
Above setting gives problems:
  • I2C not working (i2c scanner just dies)
  • pin assignment just plainly wrong (pin 6 mapped to a2 output on the board, for example)
What would be the correct settings for the platformio.ini file? I am happy for any hints. Thank you!
Seeeduino Lotus Cortex-M0+ - Seeed Wiki says you need to select the “Seeeduino Zero” for it, which does exist. So just set board = seeed_zero.
Oh, indeed! :blush: Thank you so much.
In the meantime, I found that the Lotus board also is compatible with the Arduino Zero, so …
[env:zeroUSB]
platform = atmelsam
board = zeroUSB
… would also work.
