I am complete beginner in this programming and MCU, so i am not sure if what i am doing is correct or no.
I am trying to use “rei-vilo/SD” SD Library with TI TM4C 132 Board, but file is not Compile, I am doing the following:
The platform.ini is as following:
[env:lptm4c123gh6pm]
platform = titiva
board = lptm4c123gh6pm
SPI
rei-vilo/SD@0.0.0-alpha+sha.a8a1454af9
lib_ldf_mode = chain+
build_flags = -Dyield()=delay(0)
platform_packages =
framework-energiativa@https://github.com/maxgerhardt/tivac-core.git
platformio/toolchain-gccarmnoneeabi@~1.80301.0
The code i am trying to run is the following:
#include <SPI.h>
#include <C:/Repo/Test/.pio/libdeps/lptm4c123gh6pm/SD/SD.h>
//bool begin(uint8_t chipSelectPin, uint8_t sckRateID = SPI_HALF_SPEED, int8_t SPI_Port = -1, int8_t cardDetectionPin = -1,int8_t level = LOW);
// set up variables using the SD utility library functions:
Sd2Card card;
const int chipSelect = PA_3; //cs PIN
void setup()
// Open serial communications and wait for port to open:
Serial.begin(9600);
Serial.print("\nInitializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(12, OUTPUT); // change this to 53 on a mega
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(chipSelect, SPI_HALF_SPEED, 0)) { // 2 is the SPI module number here.
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card is inserted?");
Serial.println("* Is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
} else {
Serial.println("Wiring is correct and a card is present.");
void loop(void) {
When compiling, it gives the following error:
Processing lptm4c123gh6pm (platform: titiva; board: lptm4c123gh6pm; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/titiva/lptm4c123gh6pm.html PLATFORM: TI TIVA (3.1.0) > TI LaunchPad (Tiva C) w/ tm4c123 (80MHz)
HARDWARE: LPTM4C123GH6PM 80MHz, 32KB RAM, 256KB Flash
DEBUG: Current (ti-icdi) On-board (ti-icdi)
- framework-energiativa @ 1.10004.0+sha.964fac0 (git+https://github.com/maxgerhardt/tivac-core.git)
- toolchain-gccarmnoneeabi @ 1.80301.190214 (8.3.1)
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Framework incompatible library C:\Repo\Test\.pio\libdeps\lptm4c123gh6pm\SD
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Found 11 compatible libraries
|-- SPI @ 1.0.0 (License: Unknown, Path: C:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\libraries\SPI)
arm-none-eabi-g++ -o .pio\build\lptm4c123gh6pm\src\main.cpp.o -c -fno-rtti -fno-exceptions -fno-threadsafe-statics -std=gnu++11 -mthumb -Os -ffunction-sections -fd
ata-sections -Wall -nostdlib -mcpu=cortex-m4 -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 --param max-inline-insns-single=500 -DF_CPU=80000000L -DPLATFORMIO=60105 -DENERGIA_ARCH_TIVAC -DENERGIA_EK_TM4C123GXL -Dyield()=delay(0) -DARDUINO=10805 -DENERGIA=10004 -Dprintf=iprintf -Iinclude -Isrc -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\libraries\SPI -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\system -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\system\inc -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\system\driverlib -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\cores\tivac -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\variants\EK-TM4C123GXL src\main.cppsrc\main.cpp:3:10: fatal error: SD.h: No such file or directory
* Looking for SD.h dependency? Check our library registry!
* CLI > platformio lib search "header:SD.h"
* Web > https://registry.platformio.org/search?q=header:SD.h
#include <SD.h>
compilation terminated.
*** [.pio\build\lptm4c123gh6pm\src\main.cpp.o] Error 1
=================================================================== [FAILED] Took 2.58 seconds ===================================================================
* The terminal process "C:\Users\Bashar\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'lptm4c123gh6pm'" terminated with exit code: 1.
Even after i update the path in the file “c_cpp_properties.json” or also using the UI edit configuration as below, i am still getting the same result as above.
"configurations": [
"name": "PlatformIO",
"includePath": [
"c:/Repo/Test/include",
"c:/Repo/Test/src",
"C:/Repo/Test/.pio/libdeps/lptm4c123gh6pm/SD/",
"C:/Repo/Test/.pio/libdeps/lptm4c123gh6pm/SD/utility/",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/SPI",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/system",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/system/inc",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/system/driverlib",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/cores/tivac",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/variants/EK-TM4C123GXL",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/AIR430BoostEuropeETSI",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/AIR430BoostEuropeETSI/utility",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/AIR430BoostUSAFCC",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/AIR430BoostUSAFCC/utility",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/EEPROM/src",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/EduBPMKII_Screen",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/Ethernet",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/Ethernet/utility",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/Kentec_35_SPI/src",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/LiquidCrystal/src",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/Servo",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/WiFi",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/WiFi/utility",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/Wire/src"
"browse": {
"limitSymbolsToIncludedHeaders": true,
"path": [
"c:/Repo/Test/src",
"C:/Users/Bashar/.platformio/packages/framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20/libraries/Wire/src",
"defines": [
"F_CPU=80000000L",
"PLATFORMIO=60105",
"ENERGIA_ARCH_TIVAC",
"ENERGIA_EK_TM4C123GXL",
"yield()=delay(0)",
"ARDUINO=10805",
"ENERGIA=10004",
"printf=iprintf",
"cStandard": "c11",
"cppStandard": "c++11",
"compilerPath": "C:/Users/Bashar/.platformio/packages/toolchain-gccarmnoneeabi/bin/arm-none-eabi-gcc.exe",
"compilerArgs": [
"-mthumb",
"-mcpu=cortex-m4",
"-mabi=aapcs",
"-mfloat-abi=hard",
"-mfpu=fpv4-sp-d16",
"version": 4
I tried update the path in the include (h) files
- #Include <SD.h> in the main.cpp
- #include </utility/SdFat.h> in the SD.h file
- #include <utility/SdFatUtil.h> in the SD.h file
(To be honest, not sure if this is a a good thing to do based on compiling result)
So they would be looking as following:
#include <C:/Repo/Test/.pio\libdeps/lptm4c123gh6pm/SD/SD.h>
#include <C:/Repo/Test/.pio/libdeps/lptm4c123gh6pm/SD/utility/SdFat.h>
#include <C:/Repo/Test/.pio/libdeps/lptm4c123gh6pm/SD/utility/SdFatUtil.h>
And the result from compiling was as following:
ata-sections -Wall -nostdlib -mcpu=cortex-m4 -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 --param max-inline-insns-single=500 -DF_CPU=80000000L -DPLATFORMIO=60105 -DENERGIA_ARCH_TIVAC -DENERGIA_EK_TM4C123GXL -Dyield()=delay(0) -DARDUINO=10805 -DENERGIA=10004 -Dprintf=iprintf -Iinclude -Isrc -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\libraries\SPI -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\system -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\system\inc -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\system\driverlib -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\cores\tivac -IC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\variants\EK-TM4C123GXL src\main.cpparm-none-eabi-g++ -o .pio\build\lptm4c123gh6pm\firmware.elf -T lm4fcpp_blizzard.ld -mthumb -Os -nostartfiles -nostdlib -mcpu=cortex-m4 -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Wl,--entry=ResetISR -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -fsingle-precision-constant .pio\build\lptm4c123gh6pm\src\main.cpp.o -LC:\Users\Bashar\.platformio\platforms\titiva\ldscripts -L.pio\build\lptm4c123gh6pm -LC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\variants\EK-TM4C123GXL -LC:\Users\Bashar\.platformio\packages\framework-energiativa@src-6b41a908e28e87862f6277c517fd5c20\system\driverlib -Wl,--start-group .pio\build\lptm4c123gh6pm\lib311\libSPI.a -lc -lgcc -lm -ldriverlib .pio\build\lptm4c123gh6pm\libFrameworkEnergia.a -Wl,--end-group c:/users/bashar/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio\build\lptm4c123gh6pm\sr
c\main.cpp.o: in function `setup': main.cpp:(.text.setup+0x2c): undefined reference to `Sd2Card::init(unsigned char, unsigned char, signed char, signed char, signed char)'
*** [.pio\build\lptm4c123gh6pm\firmware.elf] Error 1
=================================================================== [FAILED] Took 3.50 seconds ===================================================================
After many trails of uninstalling the vs code and Platformio still getting the same result.
Please if anyone knows what is wrong and can help me to resolve it.
Thanks in advance for the support.
