aldope
September 19, 2020, 12:26am
1
Hi, I recently moved to LittleFS and I can’t do my pre script for uploadfs to work. I’ve been using it with SPIFFS to Gzip web files before upload and works great.
My level of knowledge is basic so anyone cant point me how I correct this?
From what i’ve saw the script its never called
This is my platformio.ini
[env:d1_mini]
;platform = espressif8266@2.4.0
board = d1_mini
monitor_speed = 921600
extra_scripts = post:scripts/prepare_SPIFFS.py
ArduinoJson@>=6.14.1
ESPAsyncTCP@>=1.2.2
ESP Async WebServer@>=1.2.3
TaskScheduler@>=3.1.2
JC_Button@>=2.1.2
So what’s the content of this magic file?
aldope
September 19, 2020, 12:41am
3
# SCRIPT TO GZIP CRITICAL FILES FOR ACCELERATED WEBSERVING
# see also https://community.platformio.org/t/question-esp32-compress-files-in-data-to-gzip-before-upload-possible-to-spiffs/6274/10
# Ampliamente modificado Ver original en el link citado anteriormente
Import( 'env', 'projenv' )
import os
import gzip
import shutil
import glob
# Funcion complementaria para utilizar gzip
def gzip_file( src_path, dst_path ):
with open( src_path, 'rb' ) as src, gzip.open( dst_path, 'wb' ) as dst:
for chunk in iter( lambda: src.read(4096), b"" ):
dst.write( chunk )
# Comprime los archivos definidos de 'data_src/' en 'data/'
def gzip_webfiles( source, target, env ):
# Tipos de archivos que necesitan ser comprimidos
filetypes_to_gzip = [ 'css', 'html', 'js' ]
print( '\nGZIP: Iniciando el proceso de gzipeado para la imágen SPIFFS...\n' )
data_src_dir_path = os.path.join(env.get('PROJECT_DIR'), 'data_src')
data_dir_path = env.get( 'PROJECTDATA_DIR' )
# Verifica si existen data y datasrc. Si existe el primero y no el segundo lo renombra
if(os.path.exists(data_dir_path) and not os.path.exists(data_src_dir_path) ):
print('GZIP: El directorio "'+data_dir_path+'" existe, "'+data_src_dir_path+'" no se encuentra.')
print('GZIP: Renombrando "' + data_dir_path + '" a "' + data_src_dir_path + '"')
os.rename(data_dir_path, data_src_dir_path)
# Elimina el directiorio 'data'
if(os.path.exists(data_dir_path)):
print('GZIP: Eliminando el directorio "data" ' + data_dir_path)
shutil.rmtree(data_dir_path)
# Recrea el directorio 'data' vacío
print('GZIP: Re-creando un directorio de datos vacío ' + data_dir_path)
os.mkdir(data_dir_path)
# Determino los archivos a comprimir
files_to_gzip = []
for extension in filetypes_to_gzip:
files_to_gzip.extend( glob.glob( os.path.join( data_src_dir_path, '*.' + extension ) ) )
all_files = glob.glob(os.path.join(data_src_dir_path, '*.*'))
files_to_copy = list(set(all_files) - set(files_to_gzip))
#print('MEWGZIP: archivos a copiar: ' + str(files_to_gzip))
for file in files_to_copy:
print('GZIP: Copiando archivo: ' + file + ' al directorio de datos')
shutil.copy(file, data_dir_path)
# Comprime y mueve los archivos
#print('MEWGZIP: archivos a comprimir: ' + str(files_to_gzip))
was_error = False
try:
for source_file_path in files_to_gzip:
print( 'GZIP: Comprimiendo... ' + source_file_path )
#base_file_path = source_file_path.replace( source_file_prefix, '' )
target_file_path = os.path.join( data_dir_path, os.path.basename( base_file_path ) + '.gz' )
# print( 'GZIP: GZIPPING FILE...\n' + source_file_path + ' TO...\n' + target_file_path + "\n\n" )
print( 'GZIP: Comprimido... ' + target_file_path )
gzip_file( source_file_path, target_file_path )
except IOError as e:
was_error = True
print( 'GZIP: Fallo al comprimir el archivo: ' + source_file_path )
# print( 'GZIP: EXCEPTION... {}'.format( e ) )
if was_error:
print( 'GZIP: Fallo/Incomppleto.\n' )
else:
print( 'GZIP: Comprimido correctamente.\n' )
# IMPORTANT, this needs to be added to call the routine
env.AddPreAction( '$BUILD_DIR/spiffs.bin', gzip_webfiles )
aldope
September 19, 2020, 12:44am
4
Sorry, I’ve found the problem… the filename of the image
change spiffs.bin to littlefs.bin did the trick. The script its working now
to
env.AddPreAction( '$BUILD_DIR/littlefs.bin', gzip_webfiles )
If you want to be safe and indifferent towards user-defined image names or even SPIFFS/LitteFS, you should use the $ESP32_SPIFFS_IMAGE_NAME varaiable as the code shows here
ARFLAGS=["rc"],
SIZEPROGREGEXP=r"^(?:\.iram0\.text|\.iram0\.vectors|\.dram0\.data|\.flash\.text|\.flash\.rodata|)\s+([0-9]+).*",
SIZEDATAREGEXP=r"^(?:\.dram0\.data|\.dram0\.bss|\.noinit)\s+([0-9]+).*",
SIZECHECKCMD="$SIZETOOL -A -d $SOURCES",
SIZEPRINTCMD="$SIZETOOL -B -d $SOURCES",
ERASEFLAGS=[
"--chip", mcu,
"--port", '"$UPLOAD_PORT"'
ERASECMD='"$PYTHONEXE" "$OBJCOPY" $ERASEFLAGS erase_flash',
# mkspiffs package contains two different binaries for IDF and Arduino
MKFSTOOL="mk%s" % filesystem
"_${PIOPLATFORM}_"
"espidf"
if "espidf" in env.subst("$PIOFRAMEWORK")
So e.g.
env.AddPreAction( '$BUILD_DIR/${ESP32_SPIFFS_IMAGE_NAME}.bin', gzip_webfiles )
aldope
September 19, 2020, 11:20pm
6
Hi maxgerhardt thanks for ur help.
Im using esp8266 platform not esp32… its the same case?
Edit:
I looked and found this
ESP8266_FS_IMAGE_NAME
I assume this is the correct variable name for my app case right?
