Scanning dependencies takes more than 90 seconds every build
I’m using VSCode .platformio extension in Windows10.
Everything works normal except one arduino project from GITHUB.
The “Scanning dependencies” procedure takes more than 90 seconds every build, even I had never modified one single line of code.
Have tried to stop the Antivirus monitoring or use a more powerful PC, didn’t work.
VSCode version:
Version: 1.84.2 (user setup)
Commit: 1a5daa3a0231a0fbba4f14db7ec463cf99d7768e
Date: 2023-11-09T10:51:52.184Z
Electron: 25.9.2
ElectronBuildId: 24603566
Chromium: 114.0.5735.289
Node.js: 18.15.0
V8: 11.4.183.29-electron.0
OS: Windows_NT x64 10.0.19045
PlatformIO Core 6.1.11
paltformio.ini
[env:esp32]
platform = espressif32 @ 6.4.0
board = dfrobot_firebeetle2_esp32e
board_build.partitions = huge_app.csv
upload_speed = 921600
  adafruit/Adafruit BME280 Library @ ^2.2.2
  adafruit/Adafruit BusIO @ ^1.11.2
  adafruit/Adafruit Unified Sensor @ ^1.1.5
  bblanchon/ArduinoJson @ ^6.19.3
  zinggjm/GxEPD2 @ ^1.4.5
and building logs:
 *  Executing task: C:\Users\Ahe\.platformio\penv\Scripts\platformio.exe run --environment esp32
Processing esp32 (platform: espressif32 @ 6.4.0; framework: arduino; board: dfrobot_firebeetle2_esp32e)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/dfrobot_firebeetle2_esp32e.html
PLATFORM: Espressif 32 (6.4.0) > DFRobot Firebeetle 2 ESP32-E
 - framework-arduinoespressif32 @ 3.20011.230801 (2.0.11)
Found 40 compatible libraries
|-- Adafruit BME280 Library @ 2.2.2
|-- Adafruit BusIO @ 1.14.5
|-- Adafruit Unified Sensor @ 1.1.13
|-- ArduinoJson @ 6.21.3
|-- pollutant-concentration-to-aqi
|-- HTTPClient @ 2.0.0
|-- SPI @ 2.0.0
|-- WiFi @ 2.0.0
|-- WiFiClientSecure @ 2.0.0
|-- Preferences @ 2.0.0
|-- Wire @ 2.0.0
|-- GxEPD2 @ 1.5.3
Retrieving maximum program size .pio\build\esp32\firmware.elf
Checking size .pio\build\esp32\firmware.elf
RAM:   [===       ]  30.7% (used 100544 bytes from 327680 bytes)
Flash: [====      ]  39.4% (used 1239817 bytes from 3145728 bytes)
==================================================================== [SUCCESS] Took 126.26 seconds ====================================================================
Maybe an upvote for https://github.com/platformio/platformio-core/issues/4455 ?
:slight_smile:
Yes, that’s a kind of solution for my problem.
Could you provide a simple project to debug this issue? It should not take so much time.
Sure.
It’s an opensource project from GITHUB
Great project! Yes, I reproduced this issue. The same problem. The VSCode is still processing the “database” for the IntelliSense :slight_smile:
Screenshot 2023-11-27 at 20.37.52
See detailed explanation and solution
