I was trying to make my own library. But it goes wrong ^^
I am not the C++ pro. I am learning but this way was to hard.
That are my library files:
.h
#ifndef SRS_Module_h
#define SRS_Module_h#include “Arduino.h”
struct settings_t{
settings_t();
bool debug;
bool DHCP;
int FadeTime;
int IP1;
};extern settings_t settings;
class Configs
public:
void write(bool flasheeprom);
void read();
private:
bool _flasheeprom;
};#endif
.cpp
#include <extEEPROM.h>
#include “SRS_Module.h”extEEPROM myEEPROM(kbits_2, 1, 16, 0x50);
settings_t::settings_t()
debug = true;
DHCP = false;
FadeTime = 1;
IP1 = 192;
}settings_t settings;
byte i2cStat = myEEPROM.begin(myEEPROM.twiClock100kHz);
void Configs::write(bool _flash)
int EEPROMnew = myEEPROM.read(255);
if (EEPROMnew != 50 || _flash == true){
myEEPROM.write(0, settings.debug);
myEEPROM.write(1, settings.DHCP);
myEEPROM.write(2, settings.FadeTime);
myEEPROM.write(3, settings.IP1);
After uploading the SAMD21 (Arduino Zero) chip was bricked. No USB was found, No erase with Atmel Studio possible.
It tooks 3 broken Chips to find out if I delete this line all is good.
What make I wrong? I must start EEPROM that I can use the functions in the library. If I put this all in the mainfile withou my library all is working.
Regards
Steffen
