Rurn-time error - [esp32-hal-cpu.c:110] addApbChangeCallback(): duplicate func=0x400d9404 arg=0x3ffbdc50
Hi All,
A quick heads-up on a problem, which seems to be generally unexplained.
Just when I thought I’d got the bare bones of my project working (ESP32, TFT touchscreen and SD card) I noticed a run-time error on the serial monitor …
*[esp32-hal-cpu.c:110] addApbChangeCallback(): duplicate func=0x400d9404 arg=0x3ffbdc50*
I’m using TFT_eSPSI and SD libraries.
I appears the 2 libraries conflict in some way.
Google found a few references regarding the #define USE_HSPI_PORT line in User_Setup.h , but didn’t work for me.
I’ve gone back to a previous route, using build_flags in Platformio.ini.
It appears the bottom line here has stopped the error.
Might help someone.
[env:nodemcu-32s]
board = nodemcu-32s
	bodmer/TFT_eSPI@^2.5.43
	paulstoffregen/XPT2046_Touchscreen
	SD
lib_ignore = AzureIoTHubMQTTClient //=> this one also has an SD.h file which caused trouble earlier
	-D USER_SETUP_LOADED
	-D ILI9488_DRIVER
	-D TFT_WIDTH=320
	-D TFT_HEIGHT=480
	-D TFT_CS=15
	-D TFT_RST=4
	-D TFT_DC=2
	-D TFT_MOSI=23
	-D TFT_SCLK=18
	-D TFT_MISO=19
	-D TOUCH_CLK=18
	-D TOUCH_CS=5
	-D TOUCH_DIN=23
	-D TOUCH_DO=19
        -D SD_CS=22
       -D SD_MISO=19
       -D SD_CLK=18
       -D SD_MOSI=23
       -D LOAD_GLCD=1
	-D LOAD_FONT2
	-D LOAD_FONT3
	-D LOAD_FONT4
	-D LOAD_FONT6
	-D LOAD_FONT7
	-D LOAD_FONT8
	-D LOAD_GFXFF
	-D SMOOTH_FONT
	-D SPI_FREQUENCY=27000000
        -D USE_HSPI_PORT
