I have this code right here:
#include <esp_event.h>
#include <freertos/task.h>
#include <freertos/FreeRTOS.h>
#include <freertos/FreeRTOSConfig.h>
#include <Wire.h>
#include <esp_now.h>
#include <WiFi.h>
#include <cstring>
#include <esp_pm.h>
#include <esp32-hal-log.h>
#include <esp32-hal-adc.h>
#ifdef DEBUG
#include <esp_gdbstub.h>
#ifdef CONFIG_ESP_SYSTEM_PANIC_HALT
#pragma message("using CONFIG_ESP_SYSTEM_PANIC_HALT option")
#ifdef CONFIG_ESP_SYSTEM_PANIC_REBOOT
#pragma message("using CONFIG_ESP_SYSTEM_PANIC_REBOOT option")
#define TEST
#pragma message("Building TEST mode")
// TODO: add actual pin number
#define LED_PIN 2
#define VIBRATION_SENSOR_PIN 3
#define IF_SENSOR_PIN 4
#define QUEUE_LEN 64
char buf[100] = {};
const uint8_t *data = (const uint8_t*)"123";
const esp_now_peer_info_t server_info = {
.peer_addr = {0xF8, 0xB3, 0xB7, 0x45, 0x4E, 0xAC},
.lmk = {},
.channel = 1,
.ifidx = WIFI_IF_STA,
.encrypt = false,
.priv = NULL
bool should_update_server = false;
bool goal = false;
QueueHandle_t table_queue = NULL, goal_queue = NULL;
void send_callback(const uint8_t *mac_addr, esp_now_send_status_t status) {
should_update_server = status != esp_now_send_status_t::ESP_NOW_SEND_SUCCESS;
log_i("should_update_server [%p]: %d\n", &should_update_server, should_update_server);
void recv_callback(const uint8_t *mac_addr, const uint8_t *data, int len) {
std::memcpy(buf, reinterpret_cast<const char*>(data), len);
digitalWrite(18, HIGH);
log_i("got data %s\n", buf);
void listen_goal(void *param) {
uint8_t res = 0;
uint8_t a = 0;
while (1) {
log_i("queue: %p\n", table_queue);
auto k = xQueueReceive(table_queue, &res, portMAX_DELAY);
if (k) {
log_i("received %c\n", res);
auto start_cycle = cpu_ll_get_cycle_count();
log_i("a: %p\n", &a);
log_i("res: %p\n", &res);
res = 0;
// Try to read IF sensor for 100 microseconds.
while (cpu_ll_get_cycle_count() - start_cycle < microsecondsToClockCycles(100)) {
log_i("%u\n", cpu_ll_get_cycle_count() - start_cycle);
if (digitalRead(IF_SENSOR_PIN)) {
res = 1;
break;
#ifdef TEST
auto l = esp_random();
res = (uint8_t)l & 1;
log_i("received %d\n", res);
if (res) {
char msg = 'G';
auto x = xQueueSend(goal_queue, &msg, portMAX_DELAY);
log_i("got %d\n", x);
log_i("Finished sending.\n");
log_i("Finished.\n");
log_i("stack bytes remaining: %u bytes\n", uxTaskGetStackHighWaterMark(NULL));
vTaskDelay(1);
void listen_table(void *param) {
const char msg = 'T';
uint8_t res;
while (1) {
res = 0;
// Try to read vibration sensor for 100 microseconds.
if (digitalRead(VIBRATION_SENSOR_PIN)) {
res = 1;
break;
#ifdef TEST
auto k = esp_random();
res = (uint8_t)k & 1;
if (res) {
auto x = xQueueSend(table_queue, &msg, portMAX_DELAY);
auto u = uxQueueSpacesAvailable(table_queue);
log_i("got %d, space remaining: %u\n", x, u);
auto u = uxQueueMessagesWaiting(table_queue);
log_i("table: %u messages waiting.\n", u);
u = uxQueueMessagesWaiting(goal_queue);
log_i("goal: %u messages waiting.\n", u);
vTaskDelay(1);
void send_packet(void *param) {
uint8_t res = 0;
while (1) {
uint8_t a = 0;
log_i("%u messages waiting.\n", uxQueueMessagesWaiting(goal_queue));
log_i("goal_queue: %p\n", goal_queue);
if ((a = xQueuePeek(goal_queue, &res, portMAX_DELAY))) {
esp_now_send(server_info.peer_addr, data, strlen("123"));
#ifdef TEST
log_i("data: %p\n", data);
log_i("got %c\n", res);
log_i("goal_queue: %p", goal_queue);
auto u = uxQueueSpacesAvailable(goal_queue);
log_i("%u goal queue bytes remaining\n", u);
auto x = xQueueReceive(goal_queue, &res, 0);
log_i("received data: %d\n", x);
if (!should_update_server) {
// auto x = xQueueReceive(goal_queue, &res, 0);
log_i("a: %d, Finished.\n", a);
vTaskDelay(1);
WiFi.mode(WIFI_STA);
#ifdef DEBUG
esp_gdbstub_init();
pinMode(IF_SENSOR_PIN, INPUT);
pinMode(LED_PIN, OUTPUT);
pinMode(VIBRATION_SENSOR_PIN, INPUT);
ESP_ERROR_CHECK(esp_now_init());
ESP_ERROR_CHECK(esp_now_add_peer(&server_info));
ESP_ERROR_CHECK(esp_now_register_send_cb(esp_now_send_cb_t(send_callback)));
ESP_ERROR_CHECK(esp_now_register_recv_cb(esp_now_recv_cb_t(recv_callback)));
#ifdef ENABLE_SLEEP
ESP_ERROR_CHECK(esp_sleep_enable_wifi_wakeup());
esp_pm_config_esp32_t pm_cfg;
ESP_ERROR_CHECK(esp_pm_get_configuration(&pm_cfg));
pm_cfg.light_sleep_enable = true;
ESP_ERROR_CHECK(esp_pm_configure(&pm_cfg));
if (xTaskCreatePinnedToCore(
listen_table,
"listen_table",
4096,
NULL,
0,
NULL,
1
) == errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY) {
log_e("Failed to allocate memory for %s task.\n", "listen_table");
abort();
listen_goal,
"listen_goal",
4096,
NULL,
0,
NULL,
0
log_e("Failed to allocate memory for %s task.\n", "listen_goal");
abort();
send_packet,
"send_packet",
4096,
NULL,
0,
NULL,
1
log_e("Failed to allocate memory for %s task.\n", "send_packet");
abort();
table_queue = xQueueCreate(QUEUE_LEN, (sizeof(char)));
if (!table_queue) {
log_e("Failed to allocate memory for table_queue.\n");
abort();
goal_queue = xQueueCreate(QUEUE_LEN, (sizeof(char)));
if (!goal_queue) {
log_e("Failed to allocate memory for goal_queue.\n");
abort();
// Delete unused loop task
vTaskDelete(NULL);
From what I can see on the crash coredump, the code always store a garbage value on EXECVADDR (around 0x0) so I assume there is an invalid pointer dereference somewhere, but I can’t seem to find it since I allocate everything in global/local scope with no calls to malloc() and other memory allocation functions. The crash always happens when calling send_packet(). Can anyone point out the issues in my code? Thanks in advance.
