Please find as in my build error logs below, I am writing test cases for an application which uses zephyr driver files, The build system is able to locate the zephyr driver file,
but unable to locate the zephyr.h file & other dependent files
Kindly someone suggest on how zephyr can be included on pio to run gtest.
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell https://aka.ms/pscore6
PS D:\spi_test> platformio.exe test --environment native
Collected 1 items
Processing native in native environment
---------------------------------------------------------------------------------------------------------------------Building...
In file included from lib\calculator\uC_SPI.h:17,
from lib\calculator\uC_SPI.cpp:15:
lib\calculator/uC_IO_Define.h:20:10: fatal error: zephyr.h: No such file or directory
* Looking for zephyr.h dependency? Check our library registry!
* CLI > platformio lib search "header:zephyr.h"
* Web > https://platformio.org/lib/search?query=header:zephyr.h
#include "zephyr.h"
compilation terminated.
*** [.pio\build\native\libfcb\calculator\uC_SPI.o] Error 1
In file included from lib\calculator/uC_SPI.h:17,
from test\native\test.cpp:3:
#include "zephyr.h"
*** [.pio\build\native\test\native\test.o] Error 1
============================================ [FAILED] Took 10.01 seconds ============================================
Test Environment Status Duration
native native FAILED 00:00:10.005
